Question / Help Need help ASAP
Anarchy
I have a gtx 1080 and i7 4.20GHz and if someone could help me with my settings, i wish to record at 1080p 60fps and stream at 1080p 30fps
Xsoulsin
you can try this as starting point you can choose Tools->Auto Configuration Wizard to create a config suitable for a start for streaming, also does depend on your upload speed and what type streaming service you like to use. As for Recording I dont have much info on that but someone else could provide info about what can use as starting point, the auto config may give idea also on recording.
Twitch
https://help.twitch.tv/customer/en/portal/articles/1253460-broadcast-requirements
https://stream.twitch.tv/
Youtube
https://support.google.com/youtube/answer/2853702?hl=en&ref_topic=6136989
This Tool will help you get idea with which Twitch server stream to if you use Twitch, to have good quality needs to be 80+
http://www.teamliquid.net/forum/tech-support/478845-twitchtest-twitch-bandwidth-tester
Anarchy
Twitch
Youtube
I already stream on twitch and it work well for the most part but recording was my only big problem
