Question / Help Need Help Adjusting Streaming And Recording Settings
Brandon Mckenna
I tried to stream but its really laggy and I tried recording as well and the quality looked okay but the video got stuck alot and I ened up deleting it due to it being stuck on one frame then skipping to another ..... I at least want the quality to run at 480p at 30FPS .. Can anyone help me ..
07:07:05.776: CPU Name: Intel(R) Celeron(R) CPU N2840 @ 2.16GHz
07:07:05.780: CPU Speed: 2167MHz
07:07:05.781: Physical Cores: 2, Logical Cores: 2
07:07:05.782: Physical Memory: 3977MB Total, 1066MB Free
07:07:05.782: Windows Version: 10.0 Build 10240 (revision: 16384)
07:07:05.782: Aero is Enabled (Aero is always on for windows 8 and above)
07:07:05.819: OBS 0.12.3 (64bit, windows)
07:07:05.819: ---------------------------------
07:07:05.821: ---------------------------------
07:07:05.822: audio settings reset:
07:07:05.822: samples per sec: 44100
07:07:05.822: speakers: 2
07:07:05.822: buffering (ms): 1000
07:07:05.831: ---------------------------------
07:07:05.831: Initializing D3D11..
07:07:05.831: Available Video Adapters:
07:07:05.838: Adapter 0: Intel(R) HD Graphics
07:07:05.859: Loading up D3D11 on adapter Intel(R) HD Graphics (0)
07:07:05.872: D3D11 loaded sucessfully, feature level used: 45056
07:07:08.848: ---------------------------------
07:07:08.848: video settings reset:
07:07:08.848: base resolution: 1366x768
07:07:08.848: output resolution: 1092x614
07:07:08.848: fps: 30/1
07:07:08.848: format: NV12
dping
I'm moving this post to the correct place. use quicksync instead of x264. you dont have enough CPU power to use software encoding.
