i get 100 down / 20 up (Mbps)
I tried lowering the output all the way down to 240p @60 and I still drop frames.. So obviously there is something very wrong. If someone could please help me not drop frames it would be immensely appreciated, thanks.
07:04:01: Open Broadcaster Software v0.541b - 32bit (´・ω・`)
07:04:01: -------------------------------
07:04:01: CPU Name: AMD FX(tm)-6100 Six-Core Processor
07:04:01: CPU Speed: 3311MHz
07:04:01: Physical Memory: 4095MB Total, 2850MB Free
07:04:01: stepping id: 2, model 1, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 6, total cores 3
07:04:01: monitor 1: pos={0, 0}, size={1920, 1080}
07:04:01: monitor 2: pos={-1360, 0}, size={1360, 768}
07:04:01: Windows Version: 6.2 Build 9200
07:04:01: Aero is Enabled
07:04:01: OBS Modules:
07:04:01: Base Address Module
07:04:01: 00340000 OBS.exe
07:04:01: 65D40000 OBSApi.dll
07:04:01: 68DA0000 DShowPlugin.dll
07:04:01: 67C30000 GraphicsCapture.dll
07:04:01: 67C10000 NoiseGate.dll
07:04:01: 67B60000 PSVPlugin.dll
07:04:01: ------------------------------------------
07:04:01: Adapter 1
07:04:01: Video Adapter: AMD Radeon HD 7800 Series
07:04:01: Video Adapter Dedicated Video Memory: 1054023680
07:04:01: Video Adapter Shared System Memory: 3240878080
07:04:01: Adapter 2
07:04:01: Video Adapter: NVIDIA GeForce GT 640
07:04:01: Video Adapter Dedicated Video Memory: 2091712512
07:04:01: Video Adapter Shared System Memory: 2147479552
07:04:01: =====Stream Start: 2013-07-14, 07:04:01===============================================
07:04:01: Multithreaded optimizations: On
07:04:01: Base resolution: 1280x720
07:04:01: Output resolution: 1280x720
07:04:01: Loading up D3D10...
07:04:01: Playback device Default
07:04:01: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
07:04:01: Using auxilary audio input: Microphone (Webcam C260)
07:04:01: Audio Encoding: AAC
07:04:01: bitrate: 128
07:04:01: device: Logitech Webcam C260,
07:04:01: device id \\?\usb#vid_046d&pid_081a&mi_00#7&1c59dfe&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
07:04:01: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000, fourCC: 'I420'
07:04:01: audio device: Disable,
07:04:01: audio device id Disabled,
07:04:01:
07:04:01: Using directshow input
07:04:02: ------------------------------------------
07:04:02: device: AVerMedia HD Capture C985 Bus 7,
07:04:02: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&267e22b8&0&0048#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
07:04:02: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
07:04:02:
07:04:02: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
07:04:02: Using directshow input
07:04:03: ------------------------------------------
07:04:03: Video Encoding: x264
07:04:03: fps: 45
07:04:03: width: 1280, height: 720
07:04:03: preset: veryfast
07:04:03: CBR: yes
07:04:03: CFR: no
07:04:03: max bitrate: 11000
07:04:04: Using RTMP service: Twitch / Justin.tv
07:04:04: Server selection: rtmp://live-iad-backup.justin.tv/app
07:04:06: SO_SNDBUF was at 65536
07:04:06: SO_SNDBUF is now 65536
07:04:28: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 4194304
07:30:36: Total frames rendered: 66881, number of frames that lagged: 4001 (5.98%) (it's okay for some frames to lag)
07:30:37: RTMPPublisher::SocketLoop: Aborting due to bStopping
07:30:37: Number of times waited to send: 767, Waited for a total of 3072398 bytes
07:30:37: Number of b-frames dropped: 14368 (22%), Number of p-frames dropped: 15237 (23%), Total 29605 (44%)
07:30:38: =====Stream End: 2013-07-14, 07:30:38=================================================
07:41:16: =====Stream Start: 2013-07-14, 07:41:16===============================================
07:41:16: Multithreaded optimizations: On
07:41:16: Base resolution: 1280x720
07:41:16: Output resolution: 424x240
07:41:16: ------------------------------------------
07:41:16: Loading up D3D10...
07:41:16: Playback device Default
07:41:16: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
07:41:16: Using auxilary audio input: Microphone (Webcam C260)
07:41:16: Audio Encoding: AAC
07:41:16: bitrate: 128
07:41:16: device: Logitech Webcam C260,
07:41:16: device id \\?\usb#vid_046d&pid_081a&mi_00#7&1c59dfe&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
07:41:16: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000, fourCC: 'I420'
07:41:16: audio device: Disable,
07:41:16: audio device id Disabled,
07:41:16:
07:41:16: Using directshow input
07:41:17: ------------------------------------------
07:41:17: device: AVerMedia HD Capture C985 Bus 7,
07:41:17: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&267e22b8&0&0048#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
07:41:17: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
07:41:17:
07:41:17: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
07:41:17: Using directshow input
07:41:18: ------------------------------------------
07:41:18: Video Encoding: x264
07:41:18: fps: 60
07:41:18: width: 424, height: 240
07:41:18: preset: veryfast
07:41:18: CBR: yes
07:41:18: CFR: no
07:41:18: max bitrate: 11000
07:41:19: Using RTMP service: Twitch / Justin.tv
07:41:19: Server selection: rtmp://live-iad-backup.justin.tv/app
07:41:20: SO_SNDBUF was at 65536
07:41:20: SO_SNDBUF is now 65536
07:41:31: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 1048576
07:44:05: Total frames rendered: 9530, number of frames that lagged: 1052 (11.04%) (it's okay for some frames to lag)
07:44:06: RTMPPublisher::SocketLoop: Aborting due to bStopping
07:44:06: Number of times waited to send: 41, Waited for a total of 160808 bytes
07:44:06: Number of b-frames dropped: 351 (3.8%), Number of p-frames dropped: 355 (3.8%), Total 706 (7.6%)
07:44:06: =====Stream End: 2013-07-14, 07:44:06=================================================
07:46:09: =====Stream Start: 2013-07-14, 07:46:09===============================================
07:46:09: Multithreaded optimizations: On
07:46:09: Base resolution: 1280x720
07:46:09: Output resolution: 1280x720
07:46:09: ------------------------------------------
07:46:09: Loading up D3D10...
07:46:09: Playback device Default
07:46:09: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
07:46:09: Using auxilary audio input: Microphone (Webcam C260)
07:46:09: Audio Encoding: AAC
07:46:09: bitrate: 128
07:46:09: device: Logitech Webcam C260,
07:46:09: device id \\?\usb#vid_046d&pid_081a&mi_00#7&1c59dfe&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
07:46:09: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000, fourCC: 'I420'
07:46:09: audio device: Disable,
07:46:09: audio device id Disabled,
07:46:09:
07:46:10: Using directshow input
07:46:10: ------------------------------------------
07:46:10: device: AVerMedia HD Capture C985 Bus 7,
07:46:10: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&267e22b8&0&0048#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
07:46:10: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
07:46:10:
07:46:10: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
07:46:11: Using directshow input
07:46:11: ------------------------------------------
07:46:11: Video Encoding: x264
07:46:11: fps: 60
07:46:11: width: 1280, height: 720
07:46:11: preset: veryfast
07:46:11: CBR: yes
07:46:11: CFR: no
07:46:11: max bitrate: 9000
07:46:12: Using RTMP service: Twitch / Justin.tv
07:46:12: Server selection: rtmp://live-iad-backup.justin.tv/app
07:46:14: SO_SNDBUF was at 65536
07:46:14: SO_SNDBUF is now 65536
07:46:40: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 4194304
07:47:43: Total frames rendered: 4516, number of frames that lagged: 686 (15.19%) (it's okay for some frames to lag)
07:47:44: okay, this is strange
07:47:44: RTMPPublisher::SocketLoop: Aborting due to loop exit
07:47:44: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
07:47:44: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
07:47:44: Number of times waited to send: 38, Waited for a total of 148066 bytes
07:47:44: Number of b-frames dropped: 622 (14%), Number of p-frames dropped: 561 (13%), Total 1183 (27%)
07:47:44: =====Stream End: 2013-07-14, 07:47:44=================================================
07:54:48:
07:54:48: Profiler results:
07:54:48:
07:54:48: ==============================================================
07:54:48: frame - [100%] [avg time: 10.942 ms (cpu time: avg 5.964 ms, total 482730 ms)] [avg calls per frame: 1] [children: 84.7%] [unaccounted: 15.3%]
07:54:48: | scene->Preprocess - [28.5%] [avg time: 3.116 ms (cpu time: avg 2.239 ms, total 181258 ms)] [avg calls per frame: 1]
07:54:48: | video encoding and uploading - [56.2%] [avg time: 6.147 ms (cpu time: avg 3.17 ms, total 256606 ms)] [avg calls per frame: 1] [children: 54.8%] [unaccounted: 1.35%]
07:54:48: | | CopyResource - [0.292%] [avg time: 0.032 ms (cpu time: avg 0.019 ms, total 1544.41 ms)] [avg calls per frame: 0]
07:54:48: | | conversion to 4:2:0 - [0.228%] [avg time: 0.025 ms (cpu time: avg 0.013 ms, total 1076.41 ms)] [avg calls per frame: 0]
07:54:48: | | call to encoder - [51.4%] [avg time: 5.619 ms (cpu time: avg 2.856 ms, total 231194 ms)] [avg calls per frame: 0]
07:54:48: | | sending stuff out - [2.95%] [avg time: 0.323 ms (cpu time: avg 0.221 ms, total 17924.5 ms)] [avg calls per frame: 0]
07:54:48: | Convert444Threads - [209%] [avg time: 22.86 ms (cpu time: avg 2.579 ms, total 208745 ms)] [avg calls per frame: 0]
07:54:48:
