I have a configuration of two computers. I use ndi for obs. I divided the tracks with sound and held them separately on the second PC. I was getting delays relative to the video. By setting the delay mode low ( experimental) on the PC stream, the problem with the sound and video out of sync was solved, but I got micro lags on the stream. This is also noticeable in the preview on the PC stream. In the "statistics" tab, there are no losses in any of the parameters. Everything is fine on the gaming PC. I attach 2 log files from both PCs. I hope my question is clearly stated. Maybe someone will tell you what the problem is based on the event log files.
