Question / Help My OBS stream will work for a few seconds, then crash.
Flameotic
Here's the log:
15:45:44: =====Stream Start: 2014-08-13, 15:45:44===============================================
15:45:44: Multithreaded optimizations: On
15:45:44: Base resolution: 1600x900
15:45:44: Output resolution: 1600x900
15:45:44: ------------------------------------------
15:45:44: Loading up D3D10 on AMD Radeon HD 7310 Graphics (Adapter 1)...
15:45:44: Audio Format: 48000 Hz
15:45:44: Audio Channels: 2 Ch
15:45:44: Playback device {0.0.0.00000000}.{0fffb2f7-f191-4bf4-8da9-19364a35db5b}
15:45:44: Using desktop audio input: Speakers (Conexant High Definition Audio)
15:45:44: Global Audio time adjust: 0
15:45:44: Audio Encoding: AAC
15:45:44: bitrate: 128
15:45:44: Using Monitor Capture
15:45:44: Using Window Capture
15:45:44: Scene buffering time set to 700
15:45:44: x264: MB rate (342000) > level limit (245760)
15:45:44: Video Encoding: x264
15:45:44: fps: 60
15:45:44: width: 1600, height: 900
15:45:44: preset: veryfast
15:45:44: profile: main
15:45:44: keyint: 120
15:45:44: CBR: yes
15:45:44: CFR: yes
15:45:44: max bitrate: 100
15:45:44: buffer size: 100
15:45:50: Total frames encoded: 34, total frames duplicated: 20 (58.82%)
15:45:50: Number of frames skipped due to encoder lag: 18 (52.94%)
15:45:50: Total frames rendered: 66, number of late frames: 1 (1.52%) (it's okay for some frames to be late)
15:45:50:
15:45:50: Profiler time results:
15:45:50:
15:45:50: ==============================================================
15:45:50: video thread frame - [100%] [avg time: 6.73 ms] [children: 41.6%] [unaccounted: 58.4%]
15:45:50: | scene->Preprocess - [26.8%] [avg time: 1.804 ms]
15:45:50: | GPU download and conversion - [14.8%] [avg time: 0.997 ms] [children: 13.4%] [unaccounted: 1.38%]
15:45:50: | | flush - [11.9%] [avg time: 0.804 ms]
15:45:50: | | CopyResource - [0.906%] [avg time: 0.061 ms]
15:45:50: | | conversion to 4:2:0 - [0.579%] [avg time: 0.039 ms]
15:45:50: Convert444Thread - [100%] [avg time: 21.356 ms] [children: 99.7%] [unaccounted: 0.3%]
15:45:50: | Convert444toNV12 - [99.7%] [avg time: 21.292 ms]
15:45:50: encoder thread frame - [100%] [avg time: 135.071 ms] [children: 0.0104%] [unaccounted: 100%]
15:45:50: | sending stuff out - [0.0104%] [avg time: 0.014 ms]
15:45:50:
15:45:50:
15:45:50: Profiler CPU results:
15:45:50:
15:45:50: video thread frame - [cpu time: avg 3.077 ms, total 203.125 ms] [avg calls per frame: 1]
15:45:50: | scene->Preprocess - [cpu time: avg 1.657 ms, total 109.375 ms] [avg calls per frame: 1]
15:45:50: | GPU download and conversion - [cpu time: avg 0.236 ms, total 15.625 ms] [avg calls per frame: 1]
15:45:50: | | flush - [cpu time: avg 0.236 ms, total 15.625 ms] [avg calls per frame: 1]
15:45:50: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
15:45:50: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
15:45:50: Convert444Thread - [cpu time: avg 11.948 ms, total 203.125 ms] [avg calls per frame: 1]
15:45:50: | Convert444toNV12 - [cpu time: avg 11.029 ms, total 187.5 ms] [avg calls per frame: 1]
15:45:50: encoder thread frame - [cpu time: avg 11.948 ms, total 406.25 ms] [avg calls per frame: 1]
15:45:50: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:45:50:
15:45:50: =====Stream End: 2014-08-13, 15:45:50================================================
