Question / Help My computer is getting FPS drops and my stream is little laggy. Need help with settings.
Kaffe
Hi guys.
I love OBS compare to the free version from xsplit, but i have some problems.
I am getting FPS drop when im playing World of warcraft with OBS and i have tried so many settings so now im asking you guys insteed.
I have very good internet (Fiber 100/100)
My computer is not the best (MSI GT70 laptop) Speccs:
Intel i7 3610 QM, 2.3 Ghz, Quad core, Turbo boost up to 3.3 Ghz.
Geforce 670 GTX, 600 Mhz, 3GB DDR5
16 Gig Ram, Kingston.
SSD Disk
Playing with the lowest settings in WoW (When livestreaming) Want to play with higher settings, but im afraid i will FPS drop even more then.
Im always playing with maximum fan speed On, so the computer isnt that hot.
Im alwys playing with the CPU boost on.
So the question is: Can anyone help me with what settings i should use in OBS without getting FPS drop. Im not using my internet to anything special so you can max it all out, so my computer dont need to burn to get this fixed :)
Thx for the help and keep on the good work !
BR Kaffe
Kaffe
post a log
Well the problem is t hat im not at my computer right now. Im at work ^^ But when it comes to the some of the settings im little confused.
Max bitrate, Buffer size and what Resolution should be using in the Video settings ? One more question, What setting is making the CPU work harder so i can make the CPU work less hard in OBS and harder in WoW ? I think that is my problem.
