My audio recording goes crackly every recording! HELP!
dilzo
so i am after help, ive been recording videos for around 2 years once to twice a week, everytime now my audio input from my mic goes crackly and distorted. i have had this issue twice before and i had to uninstall and reinstall obs, however this has just been a band aid and i want a Permanente fix. Im running windows 11
so this is what happens: i open up obs check my audio recording via monitoring, once ready ill start recording and all is fine now at a random point could be 9mins 17mins or 2mins the audio goes completely distorted and crackly. sometimes i can switch the device to default or back to the interface and it will fix it for a while then itl go back to being crap.
the gear i run has not been the cause as the second time it happened i replaced everything just to find out they weren't the issue. i use a Adio Technica AT2040 with a Focusrite scarlett Solo interface, with a brand new xlr cable.
i have set the mic/interface as my default on everything
i have also made the hz etc match throughout all software and devices. all other microphone devices have been disabled. i have been searching for a solution for so long now but never can i find one. all the software is up to date. i have tried removing the filters on the mic and also removing scenes on the sources.
Below i have attached my setting to see if that helps
