John / Gaming In The Wild
Hey guys,
I'm setting up OBS for the first time on a 2018 Macbook Pro. Sorry if this n00b crap is annoying, but I could really use some help.
1. For my mic, I'm using a decent mic put through a Behringer USB mixer into the MacBook, which shows up in the inputs as "Audio USB Codec." Problem: it's currently only coming through the right side.
2. I have successfully installed and activate the iShowU extension to feature desktop sound. Problem: This works when my headphones aren't plugged into the MacBook to monitor. When I plug in headphones, the audio meter sinks to nothing, and it's headphones only with no output to Stream.
All channels are set to "Monitor and Output" in the advanced audio options.
But I feel sure I have tied the settings in a knot somewhere.
Help?
Thank you.
John
Help?
Thank you.
John
