Settings:
http://prntscr.com/532gpw
Log:
20:58:17: Open Broadcaster Software v0.637b - 64bit ( ^ω^)
20:58:17: -------------------------------
20:58:17: CPU Name: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
20:58:17: CPU Speed: 2295MHz
20:58:17: Physical Memory: 4016MB Total, 808MB Free
20:58:17: stepping id: 1, model 69, family 6, type 0, extmodel 2, extfamily 0, HTT 1, logical cores 4, total cores 2
20:58:17: monitor 1: pos={0, 0}, size={1280, 720}
20:58:17: Windows Version: 6.2 Build 9200
20:58:17: Aero is Enabled
20:58:17: OBS Modules:
20:58:17: Base Address Module
20:58:17: 0000000067AD0000 OBS.exe
20:58:17: 00000000EFCF0000 OBSApi.dll
20:58:17: 00000000F3DF0000 DShowPlugin.dll
20:58:17: 00000000F17B0000 GraphicsCapture.dll
20:58:17: 00000000F2E50000 NoiseGate.dll
20:58:17: 00000000F1780000 PSVPlugin.dll
20:58:17: ------------------------------------------
20:58:17: Adapter 1
20:58:17: Video Adapter: Intel(R) HD Graphics Family
20:58:17: Video Adapter Dedicated Video Memory: 0
20:58:17: Video Adapter Shared System Memory: 1879048192
20:58:17: Video Adapter Output 1: pos={0, 0}, size={1280, 720}, attached=true
20:58:17: =====Stream Start: 2014-11-03, 20:58:17===============================================
20:58:17: Multithreaded optimizations: On
20:58:17: Base resolution: 1280x720
20:58:17: Output resolution: 1280x720
20:58:17: Loading up D3D10 on Intel(R) HD Graphics Family (Adapter 1)...
20:58:17: Audio Format: 48000 Hz
20:58:17: Audio Channels: 2 Ch
20:58:17: Playback device Default
20:58:17: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:58:17: Global Audio time adjust: 0
20:58:18: ------------------------------------------
20:58:18: Audio Encoding: AAC
20:58:18: bitrate: 128
20:58:18: Using Monitor Capture
20:58:18: Scene buffering time set to 700
20:58:18: Video Encoding: x264
20:58:18: fps: 30
20:58:18: width: 1280, height: 720
20:58:18: preset: veryfast
20:58:18: profile: high
20:58:18: keyint: 250
20:58:18: CBR: yes
20:58:18: CFR: yes
20:58:18: max bitrate: 1000
20:58:18: buffer size: 1000
20:58:19: Total frames encoded: 8, total frames duplicated: 0 (0.00%)
20:58:19: Total frames rendered: 32, number of late frames: 1 (3.13%) (it's okay for some frames to be late)
20:58:19:
20:58:19: Profiler time results:
20:58:19:
20:58:19: ==============================================================
20:58:19: video thread frame - [100%] [avg time: 20.781 ms] [children: 91.4%] [unaccounted: 8.58%]
20:58:19: | scene->Preprocess - [90.3%] [avg time: 18.756 ms]
20:58:19: | GPU download and conversion - [1.17%] [avg time: 0.243 ms] [children: 1.61%] [unaccounted: -0.443%]
20:58:19: | | flush - [0.515%] [avg time: 0.107 ms]
20:58:19: | | CopyResource - [0.962%] [avg time: 0.2 ms]
20:58:19: | | conversion to 4:2:0 - [0.135%] [avg time: 0.028 ms]
20:58:19: Convert444Thread - [100%] [avg time: 1.499 ms] [children: 99.1%] [unaccounted: 0.934%]
20:58:19: | Convert444toNV12 - [99.1%] [avg time: 1.485 ms]
20:58:19: encoder thread frame - [100%] [avg time: 3.413 ms] [children: 0.0293%] [unaccounted: 100%]
20:58:19: | sending stuff out - [0.0293%] [avg time: 0.001 ms]
20:58:19:
20:58:19:
20:58:19: Profiler CPU results:
20:58:19:
20:58:19: video thread frame - [cpu time: avg 7.324 ms, total 234.375 ms] [avg calls per frame: 1]
20:58:19: | scene->Preprocess - [cpu time: avg 4.882 ms, total 156.25 ms] [avg calls per frame: 1]
20:58:19: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:58:19: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:58:19: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
20:58:19: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
20:58:19: Convert444Thread - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:58:19: | Convert444toNV12 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:58:19: encoder thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:58:19: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:58:19:
20:58:19: =====Stream End: 2014-11-03, 20:58:19=================================================
20:58:46: =====Stream Start: 2014-11-03, 20:58:46===============================================
20:58:46: Multithreaded optimizations: On
20:58:46: Base resolution: 1920x1080
20:58:46: Output resolution: 1280x720
20:58:46: ------------------------------------------
20:58:46: Loading up D3D10 on Intel(R) HD Graphics Family (Adapter 1)...
20:58:47: ------------------------------------------
20:58:47: Audio Format: 48000 Hz
20:58:47: Audio Channels: 2 Ch
20:58:47: Playback device Default
20:58:47: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:58:47: Global Audio time adjust: 0
20:58:47: Audio Encoding: AAC
20:58:47: bitrate: 128
20:58:47: Using Monitor Capture
20:58:47: Scene buffering time set to 700
20:58:47: Video Encoding: x264
20:58:47: fps: 30
20:58:47: width: 1280, height: 720
20:58:47: preset: veryfast
20:58:47: profile: high
20:58:47: keyint: 250
20:58:47: CBR: yes
20:58:47: CFR: yes
20:58:47: max bitrate: 1000
20:58:47: buffer size: 1000
Warning -- Capture BitBlt failed (6).. just so you know
So, please help!
EDIT: I use a 1920 x 1080 screen width computer, but this shows up:
Problem there?
