Justin Smyth
When I use monitor capture on OBS, it only seems to display a section of my screen which isn't helpful. Here is an example
my log are here .
13:53:17: Open Broadcaster Software v0.622b - 32bit (´・ω・`)
13:53:17: -------------------------------
13:53:17: CPU Name: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
13:53:17: CPU Speed: 2295MHz
13:53:17: Physical Memory: 4016MB Total, 1710MB Free
13:53:17: stepping id: 1, model 69, family 6, type 0, extmodel 2, extfamily 0, HTT 1, logical cores 4, total cores 2
13:53:17: monitor 1: pos={0, 0}, size={1280, 720}
13:53:17: Windows Version: 6.2 Build 9200
13:53:17: Aero is Enabled
13:53:17: OBS Modules:
13:53:17: Base Address Module
13:53:17: 011A0000 OBS.exe
13:53:17: 671D0000 OBSApi.dll
13:53:17: 689C0000 DShowPlugin.dll
13:53:17: 68990000 GraphicsCapture.dll
13:53:17: 68960000 NoiseGate.dll
13:53:17: 68940000 PSVPlugin.dll
13:53:17: ------------------------------------------
13:53:17: Adapter 1
13:53:17: Video Adapter: Intel(R) HD Graphics Family (Intel Corporation - WDDM 1.3)
13:53:17: Video Adapter Dedicated Video Memory: 0
13:53:17: Video Adapter Shared System Memory: 1879048192
13:53:17: Video Adapter Output 1: pos={0, 0}, size={1280, 720}, attached=true
13:53:17: =====Stream Start: 2014-05-11, 13:53:17===============================================
13:53:17: Multithreaded optimizations: On
13:53:17: Base resolution: 1920x1080
13:53:17: Output resolution: 1280x720
13:53:17: Loading up D3D10 on Intel(R) HD Graphics Family (Intel Corporation - WDDM 1.3) (Adapter 1)...
13:53:18: ------------------------------------------
13:53:18: Audio Format: 48000 Hz
13:53:18: Audio Channels: 2 Ch
13:53:18: Playback device {0.0.0.00000000}.{3afc0a02-543e-4d33-847d-b2d8936501c8}
13:53:18: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:53:18: Global Audio time adjust: 0
13:53:18: Using auxilary audio input: Microphone (Realtek High Definition Audio)
13:53:18: Using Mic QPC timestamps
13:53:18: Mic time offset: 0
13:53:18: Audio Encoding: AAC
13:53:18: bitrate: 160
13:53:18: Using bitmap image
13:53:18: Using graphics capture
13:53:18: Using anti-cheat hooking for game capture
13:53:18: Trying to hook process: HD-Agent.exe
13:53:18: Scene buffering time set to 700
13:53:18: x264: VBV maxrate specified, but no bufsize, ignored
13:53:18: Video Encoding: x264
13:53:18: fps: 30
13:53:18: width: 1280, height: 720
13:53:18: preset: veryfast
13:53:18: profile: main
13:53:18: keyint: 60
13:53:18: CBR: no
13:53:18: CFR: yes
13:53:18: max bitrate: 1000
13:53:18: buffer size: 0
13:53:18: quality: 10
13:53:18: Audio timestamp for device 'Microphone (Realtek High Definition Audio)' was behind target timestamp by 17
13:53:39: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:53:39: New Scene
13:53:39: Using text output
13:53:39: Using bitmap image
13:53:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:53:40: New Scene
13:53:40: Using graphics capture
13:53:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:53:41: New Scene
13:53:41: Using Monitor Capture
13:54:10: Using Window Capture
13:55:14: Failed loading CUDA dll
13:55:28: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:55:28: New Scene
13:55:28: Using bitmap image
13:55:39: Using text output
13:55:40: Using text output
13:56:02: Using bitmap image
13:56:25: Using text output
13:56:30: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:56:30: New Scene
13:56:40: Using Monitor Capture
13:53:17: Adapter 1
13:53:18: fps: 30
13:53:18: CBR: no
13:53:18: CFR: yes
13:53:39: New Scene
13:53:40: New Scene
13:53:41: New Scene
13:55:28: New Scene
13:56:30: New Scene
