Mixer USB Audio Source Starts Clipping After ~5 Minutes
McPyrrhic
This may be a weird and specific problem.
I use a RODE Rodecaster Duo mixer for streaming. Today, a specific USB audio sources started either clipping or showing no volume in OBS. It behaves normally for 2-5 minutes (levels are exactly the same in OBS as they are on the mixer's monitor) and then it suddenly jumps to clipping or stops showing any volume from the source. I do not touch the mixer, anything in OBS or the Windows / EarTrumpet audio settings. It just goes from working to suddenly to not.
I can re-route the specific audio sources (in this case Google Chrome and Spotify) to the other USB channel and the problem does not occur. It is specific to USB-2 and only in OBS. The Window's Volume Mixer, EarTrumpet and the physical monitor on the Rodecaster ALL show that the audio behaves as expected.
I find it odd that it behaves completely normally for a bit and then jumps to a clipping state, without any adjustment
Here is everything I've tried so far:
- Switching USB-C ports
- Swapping to different USB-C cables (x2)
- Resetting the mixer
- Updating to 32.0.1 (have since downgraded back to 31.1.2 due to plugin incompatibility)
- Reinstalling OBS / trying a portable install
- Reinstalling EarTrumpet
This audio setup is a little convoluted but I'll try to explain how it's set up.
The Rodecaster has two USB-C cables, that go to a single pc. Each cable allows for an individual audio source. I use one for system / game audio and the other for browser source / music (Spotify). There is also a number of virtual audio sources, all of which use EarTrumpet to be routed. This has worked nearly flawlessly for about two years.
I haven't seen any Windows updates that misconfigured audio settings in about a month. I only have the one PC, so I can't test another device to definitively rule out this isn't a hardware issue, but the hardware appears to be working as it always has.
Has anyone else experienced anything like this, especially with a Rodecaster mixer? I'll also be posting in RODE's forum, incase this is specifically a hardware issue.
Attached are a couple of screenshots. Apologies for the infinite mirror effect in the OBS preview
To add to the above, this is the level displayed on the mixer's physical display, at the same time the audio clips in OBS (second screenshot)
