Everything was working right. I have been running the same config for months. Today, I pressed F11 to go out of fullscreen mode and everything went screwy. with the Audio Mixer.
All Global audio sources are disabled.
I have 8 scenes. 5 potential audio sources. 3 capture devices.
1) A BMD DeckLink 4K 12G. Video through SDI, Audio through XLR.
2) An Axis PTZ, Audio not used
3) a Magewell HDMI to USB, Audio not being used
4) 2 local MP3 files.
6 scenes use the DeckLink, 2 use both local, muted independently depending on what I want to play. The 6 scenes using the Decklink used to show only that in the Audio Mixer. The other 2 would only show the local files. Under advanced properties, all audio sources would show active.
Now only the decklink shows as active and I can't remove it from the scenes where only the local files should show.
And all sound settings are now global and no longer by scene.
OBS 27.1.3 (64 bit) on Win 10
