Question / Help Mic audio works in recording but not stream.
Check your device track assignments in Edit > Advanced Audio Properties, and the track(s) being streamed and recorded in the Output tab.
You can record multiple audio tracks in a single file. You can only stream a single track. (You can have multiple devices on that track, but if you've got, say, 3 devices and you've assigned each one to one track and one track only, then the only device that will hit the stream is the one assigned to the track you are streaming.
The usual configuration is to assign devices to separate tracks as needed and reserve one final track for ALL devices, and then stream that track.
Thanks, but i have a couple questions. How do I know what track my microphone is assigned to, and which track is the one being streamed.
I attached a screenshot.
