Bug Report Mic and Capture Card Audio Lock up when Monitor enters Sleep
EpicSenseney
I have been using OBS and its a great program, but when i upgraded to the latest version(0.466a) i have noticed that whenever my monitor enters sleep mode, when i move the mouse to get the screen back up, the audio and capture card sound are frozen, and the audio cuts out completely on my stream. Video plays fine though.
PC Specs:
Intel i5 3570K OC'd to 4.0Ghz
12GB DDR3 1600mhz RAM
HD 7770 1GB GHZ Edition
ASRock Z77 Extreme3 Motherboard
500GB HDD
620W Coolermaster Slient Pro PSU
Capture Card: Blackmagic Intensity Pro
my Monitor is: Samsung "23 SyncMaster S23B550 *i have gone into my monitor settings and the screen timeout only goes up to 200sec. and there is no off setting.
Heres the Log file from yesterday
Open Broadcaster Software v0.466a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
CPU Speed: 3400MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Disabled
Adapter 1
Video Adapter: AMD Radeon HD 7700 Series
Video Adapter Dedicated Video Memory: 1047724032
Video Adapter Shared System Memory: 1823451136
Adapter 2
Video Adapter: Intel(R) HD Graphics 4000
Video Adapter Dedicated Video Memory: 67108864
Video Adapter Shared System Memory: 1711276032
Base resolution: 1280x720
Output resolution: 852x480
Loading up D3D10...
Using auxilary audio input: Microphone (Turtle Beach PX11 Headset)
Audio Encoding: AAC
bitrate: 128
device: Blackmagic WDM Capture,
device id \\?\decklink#avstream#5&38cac416&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\decklinkcapture1,
chosen type: HDYC, usingFourCC: true, res: 1280x720 - 1280x720, fps: 59.9402-59.9402, fourCC: 'HDYC'
device audio info - bits per sample: 16, channels: 2, samples per sec: 48000
Using directshow input
Using text output
Video Encoding: x264
fps: 30
width: 852, height: 480
preset: superfast
CBR: no
max bitrate: 1500
buffer size: 1800
quality: 7
Server selection: rtmp://live-lax.justin.tv/app
bufferTime: 1722, outputRateWindowTime: 1000, dropThreshold: 2222
RTMPPublisher::BufferedSend: Buffer is full (204015 / 207872 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (207213 / 207872 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (205110 / 207872 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (206172 / 207872 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (205883 / 207872 bytes), waiting to send 2246 bytes
Total frames rendered: 205581, number of frames that lagged: 43 (0.02%) (it's okay for some frames to lag)
Number of b-frames dropped: 32 (0.0067%), Number of p-frames dropped: 53 (0.011%), Total 85 (0.018%)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using text output
fps: 30
preset: superfast
CBR: no
max bitrate: 1500
buffer size: 1500
quality: 7
bufferTime: 1535, outputRateWindowTime: 1000, dropThreshold: 2035
Total frames rendered: 78450, number of frames that lagged: 3 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using text output
fps: 30
preset: superfast
CBR: no
max bitrate: 1500
buffer size: 1500
quality: 7
bufferTime: 1400, outputRateWindowTime: 1000, dropThreshold: 1900
Total frames rendered: 69932, number of frames that lagged: 2 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using text output
fps: 30
preset: superfast
CBR: no
max bitrate: 1500
buffer size: 1500
quality: 7
Total frames rendered: 28418, number of frames that lagged: 2 (0.01%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using text output
fps: 30
preset: superfast
CBR: no
max bitrate: 1500
buffer size: 1500
quality: 7
Total frames rendered: 495, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using text output
fps: 30
preset: superfast
CBR: no
max bitrate: 1500
buffer size: 1500
quality: 7
Total frames rendered: 132270, number of frames that lagged: 11 (0.01%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 3.64 ms] [avg calls per frame: 1] [children: 88.7%] [unaccounted: 11.3%]
| scene->Preprocess - [34.1%] [avg time: 1.24 ms] [avg calls per frame: 1]
| video encoding and uploading - [54.6%] [avg time: 1.987 ms] [avg calls per frame: 1] [children: 16.9%] [unaccounted: 37.7%]
| | CopyResource - [0.879%] [avg time: 0.032 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.165%] [avg time: 0.006 ms] [avg calls per frame: 0]
| | call to encoder - [15.4%] [avg time: 0.561 ms] [avg calls per frame: 0]
| | sending stuff out - [0.412%] [avg time: 0.015 ms] [avg calls per frame: 0]
So any help would be very much appreciated.
Lain
Forum Admin
Lain
Forum Moderator
Developer
Re: Mic and Capture Card Audio Lock up when Monitor enters S
I thought I had added code to prevent sleep but it appears to not be working as I thought it would. I guess I'm going to have to find out which function does it.
EpicSenseney
Ok i seemed to have fixed it for now, apparently my Asrock Motherboard's Extreme Tuner Utility set its own Power options in Windows, so it had the monitor go to sleep after 15minutes. So i just set it to "Never" and the problem doesnt happen anymore. Hopefully, i will let you know if it happens again.
Gotta Love Programs setting their own options and enabling them by default in windows...
