Maximum Quality 4K Recording Advice
Here are my settings. You need to have an Nvidia GPU on the recording PC to use HEVC_NVENC
Hey man
thanks for the screenshots, i did the exact same copy on my computer and i get a rendering lag.
My recording PC has an Rog Strix RTX 2080 TI and a i9 9900K
I was busy with work so i couldnt react to your message, i appreciate it a lot btw
I see you're using 60fps so that may be why it lags. Try 30fps. Also set it to SRGB instead of 709 color, that might help reduce processing
