Max Audio Buffering
Looking4help
Greetings
I noticed that streams with "Max Audio Buffering reached" logged had dropped and skipped frames after roughly 30 minutes when I used a RX 580. Disabling audio device timestamps solved this problem.
I've since replaced that card with a RX 6650 XT and switched to hardware encoding, yet logs show the same buffering issue until, yet again, I disable Device Timestamps for my Desktop Audio source. I am confused about this as my CPU should have more resources to spare now.
Will leaving Device Timestamps off potentially lead to audio/video sync issues? Is there any alternative to resolve this while leaving them enabled?
Assuming your CPU isn't being overtaxed then for whatever reason your system is setting incorrectct timestamps for the audio
