Hi there. For the past couple of weeks I've started to encounter an audio issue that happens almost every time I stream. All audio, mic and all stream audio via GoXLR, and my game audio coming in via an Elgato capture card (2nd PC), turns into a robot voice. Only way to resolve it is to restart OBS (kill the stream) or to kill the "Windows Audio Device Graph Isolation" in the task manager. This resets all my audio coming in so I have to restart my GoXLR software and restart any other audio I have playing, but I don't have to restart the stream.
When I check the logs via the analyzer it says the critical error is "Max Audio Buffer Reached". When I look into the logs I see this line:
09:11:27.676: Max audio buffering reached!
09:11:27.676: adding 618 milliseconds of audio buffering, total audio buffering is now 960 milliseconds (source: Sony)
Sony would be the camera I use for my webcam, however there is no audio coming in from the camera, I disabled it in the camera. I've also muted and removed that audio track from the sources. I've streamed using both X.264 and NVENC, different bit rates, and different resolutions. My CPU usage never goes above 35% in OBS and never above 70% in over all CPU usage in the task manager. So when it says "This is an indicator of very high system load" I'm not sure where to look since CPU usage is low, especially when I stream via NVENC (GPU).
Thoughts? Any additional info you need let me know. Log file attached. Thanks!
