arthur_morgan
I have written a small Lua script to record a few files with a predefined duration (these are mock durations). The script is only recording 7 files and these recordings are not of predefined duration. First and second file records fine then everything is a mess. Please help. Im on Windows 11 and OBS Studio 30.1 Beta 1.
Lua:
obs = obslua
-- Define the durations of each clip in seconds
local clip_durations = {10, 3, 4, 4, 4, 2, 2, 3}
local current_clip = 1
-- Flag to ensure stop_recording doesn't schedule more clips once done
local recording_completed = false
function script_load(settings)
obs.timer_add(start_initial_delay, 10000) -- 10 seconds initial delay
end
function start_initial_delay()
obs.timer_remove(start_initial_delay) -- Ensure the timer is removed
record_clip()
end
function record_clip()
if current_clip > #clip_durations then
recording_completed = true -- Prevent further recordings
print("All clips have been recorded. Stopping the script.")
return
end
-- Start recording
obs.obs_frontend_recording_start()
print("Recording clip " .. current_clip .. " for " .. clip_durations[current_clip] .. " seconds.")
-- Schedule to stop recording after the duration
obs.timer_add(stop_recording, clip_durations[current_clip] * 1000)
end
function stop_recording()
if recording_completed then
-- Prevent execution if recording is completed
return
end
-- Stop recording
obs.obs_frontend_recording_stop()
print("Clip " .. current_clip .. " recorded.")
-- Increment to move to the next clip
current_clip = current_clip + 1
if current_clip <= #clip_durations then
-- Wait for 2 seconds before starting the next recording
obs.timer_add(delay_before_next_clip, 2000)
else
recording_completed = true -- Ensure no further recordings are scheduled
print("Recording of all clips completed.")
end
end
-- Introduce a separate function to handle delay before the next clip
function delay_before_next_clip()
obs.timer_remove(delay_before_next_clip) -- Clear the timer to prevent re-trigger
record_clip() -- Proceed to the next clip
end
function script_unload()
-- Cleanup if needed when the script is unloaded
end
