Log Attached - Extremely low fps in recording output despite high FPS whilst I was recording? Please help!
Cooba
Hi all, I just recorded about 50 minutes of gameplay, and to my horror, when I watched it back and loaded it into Adobe Premier Pro, I noticed that the FPS was stupid laggy, stuttery and overall horrible to look at.
I have absolutely no idea how you guys tweak settings and diagnose issues but I'd appreciate it massively if you could take a look at my log files and give me some ideas.
For starters I recorded in MP4 format, which I've since learned is bad, but judging by how bad the footage is, I'd have to assume something else went wrong.
My PC specs aren't bad by any means, they're as follows:
AMD Ryzen 5 3600
RTX 3060 Ti
16GB RAM
I wasn't playing a particularly demanding game either, it was fallout 4 and it was running smoothly when I was actually playing. I didn't run OBS as an Administrator either, so I could try that too. Also, I was running it on game capture. Is it worth me uninstalling OBS and reinstalling it again, or is there something I actually need to do with my PC its self?
Thanks in advance!
  • Recording log OBS.txt
rockbottom
The log is incomplete.
Run your monitor @ 60HZ.
Fix your Scenes, only (1) Display, Game or Window capture per to avoid interference.
20:51:48.804: Loaded scenes:
20:51:48.804: - scene 'Video Capture':
20:51:48.804: - source: 'Display Capture' (monitor_capture)
20:51:48.804: - source: 'Game Capture' (game_capture)
20:51:48.804: - scene 'Scene 2':
20:51:48.804: - source: 'Game Capture 2' (game_capture)
20:51:48.804: - source: 'Display Capture 2' (monitor_capture)
Encoding settings suck for recording.
21:07:23.096: codec: H264
21:07:23.096: rate_control: CBR > CQP
21:07:23.096: bitrate: 2500
21:07:23.096: cqp: 20 > 15 - 18
21:07:23.096: keyint: 250 > 2 Seconds
21:07:23.096: preset: p5
21:07:23.096: tuning: hq
21:07:23.096: multipass: qres
21:07:23.096: profile: high
21:07:23.096: width: 1920
21:07:23.096: height: 1080
21:07:23.096: b-frames: 2 > 0
21:07:23.096: lookahead: false
21:07:23.096: psycho_aq: true > false
test
