Live stream automatically stops after one hour (both 32-bit and 64-bit tested)
jesusmedinayt7
Dear OBS Studio Support Team,
I hope you are doing well.
I am experiencing an issue with OBS Studio on my Windows 10 Pro laptop.
Every time I stream live (especially to the Kick platform), my stream automatically stops after approximately 1 hour and 1 minute (about 53 seconds).
I have already tried several fixes:
  • Tested both the 64-bit and 32-bit versions of OBS Studio.
  • I currently use the 32-bit version, because it works better on my system and uses less RAM than the 64-bit version.
  • Checked my RTMP server configuration (rtmps://
  • Adjusted bitrate, resolution, and FPS settings.
  • Added the line StreamTimeout=0 to the basic.ini file.
However, the issue still happens: OBS automatically ends the stream after about one hour.
I would like to know if OBS Studio has a built-in streaming time limit for RTMP connections or if there is another configuration I can modify to prevent this automatic disconnection. I would like your help with this problem, please.
Thank you very much for your attention and any assistance you can provide to resolve this issue.
Sincerely,
Jesús Medina
OBS currently don't have a 32bit version, only 64 bit.
Such an old version (for the 32 bit) have no support.
Check, just in case, that you didn't activated a timer which can produce this behavior. Look inside Tools menu.
Actualmente, OBS no tiene una versión de 32 bits, solo de 64 bits.
Esa versión tan antigua (para 32 bits) ya no tiene soporte.
Comprueba, por si acaso, que no hayas activado un temporizador que pueda provocar este comportamiento. Busca en el menú Herramientas.
CUALQUIERA Vale, voy a descargar de nuevo la versión de 64 bits de OBS Studio y ver qué pasa. Creo recordar que hice clic en algo. ¿Hay algo más que quieras comentarme al respecto, por favor?
Be sure to follow pinned post in this forum (link in my signature) about posting your OBS Studio log from a Streaming session with the problem
