LightBurn and OBS issue
Vusta
Hi,
I'm using OBS's virtual camera (old plugin, as the new built in virtual cam does not work with LightBurn) to connect my laser cutters camera to LightBurn, via a raspberry pi running LightBurn Bridge. The problem I'm having, is when OBS is actively running the stream, LightBurn can no longer connect to the LightBurn Bridge. If I close OBS, then LightBurn sees the Bridge and I can control the laser, but I have no camera stream.
I've tried opening up ports and have set static IPs for the pi and my PC that runs LightBurn. Any ideas why OBS would cause such an issue?
OBS 27.1.3 (64-bit, Windows 10 Pro)
Thanks!
