Question / Help LGP Stream Engine w/ OBS Problem
Trunks
When i preview my stream on OBS it does not show the picture from my cap card. all i see is a black screen, is there a solution for this?
Jack0r
The Helping Squad
A user on twitter had to re-install his stream engine software (after a recent java update, not sure if that was related though), you might want to try this too. In general you just have to activate the StreamEngine output in its Avermedia Tool, then add the StreamEngine "device" to OBS using a Video Capture Device source.
It might be needed to fit the resolutions, but it should probably already show a picture without that.
Trunks
I got it to work. Apparently i had to uninstall all the Avermedia software and Re install of it again and it started showing picture! Thanks for your help
