Question / Help LGP Stream Engine Problem
meathelix
Hey guys, I have a question about LGP for some reason it only shows 1/4 of my screen and not the full screen but when I use the other video source it shows the full screen.
How do I fix this? Thank You!
Sounds like some sort of resolution mis-match. Would have to see a log file to know for sure.
Ok, So I did a fresh install of OBS and LGHD and I still get the same problem, here is my log and here are some screenshots of it. If I use the first aver option it works fine....
The LGP is outputting 1920x1080 and your base resolution is 1280x720. Select your source and press Ctrl+F to resize it automatically. Alternately set your base resolution in OBS to 1920x1080 and downscale it to 1280x720.
Thanks, I feel quite silly now I was wondering does LGP have a hotkey so when I press stream on obs it will also start recording, I hate having to click start all the time.
Just found out LGP does not save mic audio or let alone record it. Just want a peice of software that will record and live stream 3 different audio channels.
Have you thought about using Virtual Audio Cable?
You can point all the audio sources you want at a cable and the output is only one line.
My files are now all corrupted, every single one that I recorded with on LGP, crap software from avermedia once again. The type it saves as the .ts is very bad
