Question / Help LGP Stream Engine Problem and Fix
Kingdom1232
Some people may have issues with the LGP Stream Engine not showing up in OBS. Well this is one of the possible problems that is causing it to not show up and it is......
Google Chrome
Close it and then open OBS
After OBS is open then you can open Chrome Up again and LGP Stream Engine should be there.
That is what has worked for me and I hope it works for other people too.
Thank you for this it was driving me crazy trying to figure out why it wasn't showing up. Weird that Chrome only started interfering recently as I never had this problem before (at the time of Destiny release it was working without this issue for me). Anyone have any ideas what changed or what exactly is the cause of the conflict? I know skype has a similar issue.
