Question / Help Laggy Stream, Crackly Audio - Help!
Enemy
Trying to stream on Twitch.tv but I can't even get a clean stream on super basic settings. Major lagg, buffering and stuttering most of the time and even when it works breifly the mic audio is very crackly.
Most of my setup can be seen in the log but my connection speed is 75-90mb/s down and 17-20mb/s up.
If anyone could point me in the right direction I would really appreciate it.
Uploaded a log here: https://gist.github.com/ogroves/fb6e4e8a8f4cba165ec2cadc642d411a
Twitch Test:
Why you are using 44100 setting in Audio? Your capture card working at 48000. Add only one 'Video Capture Device' (or use 'Add existing/cloning' option) and post log from that setup.
1)OK, let's do it again. Log says - you have a lag, constant rendering lag. I think, that is because you are created two inputs of the same source. When you are add new source (Video Capture Device in your case) and you want to use it in different scenes, you need to select 'Add existing' and select this existing source. See the tip on page 25: https://obsproject.com/forum/resour...ware-studio-multiplatform-help-guide-pdf.365/
Try one scene, single input source, if all right - make complex scene.
2)OBS Studio Settings>Audio>Sample Rate: 48kHz
