I am facing a strange issue with OBS and it only occurs when I have the 360 wireless receiver plugged into my PC. When I go to Preview/Stream, OBS will freeze and end up "Not Responding". If I unplug the receiver and try again, then it works. What could be causing this? Anyone else experience this? Windows says all my drivers are up to date and I am running 64-bit OBS as admin. I tried with 32-bit as well. I am running on Windows 10.
Thanks and here is the log file:
15:39:31: Open Broadcaster Software v0.656b - 64bit ( ^ω^)
15:39:31: -------------------------------
15:39:31: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
15:39:31: CPU Speed: 3311MHz
15:39:31: Physical Memory: 8159MB Total, 6198MB Free
15:39:31: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
15:39:31: monitor 1: pos={0, 0}, size={1920, 1200}
15:39:31: Windows Version: 10.0 Build 10240 (revision 16384)
15:39:31: Aero is Enabled
15:39:31: OBS Modules:
15:39:31: Base Address Module
15:39:31: 000000003E810000 OBS.exe
15:39:31: 0000000021F30000 OBSApi.dll
15:39:31: 000000003CA30000 DShowPlugin.dll
15:39:31: 000000003C710000 GraphicsCapture.dll
15:39:31: 000000003F440000 NoiseGate.dll
15:39:31: 000000003EFA0000 PSVPlugin.dll
15:39:31: 000000003C110000 scenesw.dll
15:39:31: ------------------------------------------
15:39:31: Adapter 1
15:39:31: Video Adapter: NVIDIA GeForce GTX 970
15:39:31: Video Adapter Dedicated Video Memory: 4202954752
15:39:31: Video Adapter Shared System Memory: 4277712896
15:39:31: Video Adapter Output 1: pos={0, 0}, size={1920, 1200}, attached=true
15:39:31: =====Stream Start: 2015-11-06, 15:39:31===============================================
15:39:31: Multithreaded optimizations: On
15:39:31: Base resolution: 1280x720
15:39:31: Output resolution: 1280x720
15:39:31: Loading up D3D10 on NVIDIA GeForce GTX 970 (Adapter 1)...
15:39:31: Audio Format: 44100 Hz
15:39:31: Audio Channels: 2 Ch
15:39:31: Playback device {0.0.0.00000000}.{ec0fbe43-30aa-41bd-88e7-ba5efbf64de5}
15:39:31: Using desktop audio input: Speakers (Siberia v2 Frost Blue)
15:39:31: Global Audio time adjust: 0
15:39:31: Using auxilary audio input: Microphone (Siberia v2 Frost Blue)
15:39:31: Mic time offset: 0
15:39:31: Audio Encoding: AAC
15:39:31: bitrate: 112
15:39:31: device: Logitech HD Pro Webcam C920,
15:39:31: device id \\?\usb#vid_046d&pid_082d&mi_00#7&b9d46f3&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:39:31: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
15:39:31: use buffering: false - 0, fourCC: 'I420'
15:39:31: audio device: Disable,
15:39:31: audio device id Disabled,
15:39:31: audio time offset 0,
15:39:31:
15:39:31: Using directshow input
15:39:31: device: Logitech HD Webcam C525,
15:39:31: device id \\?\usb#vid_046d&pid_0826&mi_02#7&2accae68&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:39:31:
15:39:32: Using directshow input
15:39:32: Using Window Capture
15:39:32: Using Slide Show
15:39:31: Adapter 1
15:39:31:
15:39:31:
