crayzcrinkle
The default "compressor" plugin doesnt work and I dont think it ever did. For instance, if I put a gain x3 before the in built compressor function, then give that a ratio of 20:1, threshold of -11, that should mean (like in every other audio DAW out there) that any sound above -10db should be compressed by 20x. This means that an uncompressed signal that reached 0 DB before (i.e maxed out) should be compressed down to -10.5DB (i.e. 10DB of it is above the threshold, when compressed by 20x).
However, the compressor is not doing anything other than if I set the threshold really low, slightly compressing the rest of the sound. Seems like a bug or the default plugin should have been called something else to me!
Does anyone know of a plugin that works like the compressor in every other audio program out there, and as I have described above?
