Bug Report installation problems via compiling source on Sierra, plz help
rabbit2017
Hello forum members,
Thanks in advance for looking at my question.
I've ran into a compilation issue on my Mac Sierra:
CMake Error at UI/CMakeLists.txt:38 (find_package):
  By not providing "FindQt5Widgets.cmake" in CMAKE_MODULE_PATH this project
  has asked CMake to find a package configuration file provided by
  "Qt5Widgets", but CMake did not find one.
  Could not find a package configuration file provided by "Qt5Widgets" with
  any of the following names:
    Qt5WidgetsConfig.cmake
    qt5widgets-config.cmake
  Add the installation prefix of "Qt5Widgets" to CMAKE_PREFIX_PATH or set
  "Qt5Widgets_DIR" to a directory containing one of the above files.  If
  "Qt5Widgets" provides a separate development package or SDK, be sure it has
  been installed.
I manually exported the config setting, which I thought would've fixed the problem, but still running into issues:
Sashas-MacBook-Pro:build Sasha$ echo $CMAKE_PREFIX_PATH
/Users/Sasha/Qt/5.8/clang_64/lib/cmake/Qt5Widgets
PAJ
for anyone stumbling across this error I just built OBS on MacOS 10.13.x with
cmake .. -DCMAKE_PREFIX_PATH=/usr/local/Cellar/qt/5.11.1 && make package
Narcogen
On Sierra I install qt from homebrew, so I use this variable to set the path for qt:
export CMAKE_PREFIX_PATH=/usr/local/opt/qt5/
