Question / Help I use to stream a few months ago with no problems, now I have 100% CPU usage.
Th3B3ar
11:48:32.065: CPU Name: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
11:48:32.066: CPU Speed: 2808MHz
11:48:32.066: Physical Cores: 4, Logical Cores: 8
11:48:32.066: Physical Memory: 7833MB Total, 1716MB Free
11:48:32.066: Windows Version: 10.0 Build 16299 (revision: 431; 64-bit)
11:48:32.066: Running as administrator: false
11:48:32.066: Aero is Enabled (Aero is always on for windows 8 and above)
11:48:32.066: Windows 10 Gaming Features:
11:48:32.066: Game Bar: Off
11:48:32.066: Game DVR: Off
11:48:32.066: Game DVR Background Recording: Off
11:48:32.066: Game Mode: Off
11:48:32.068: Sec. Software Status:
11:48:32.069: Windows Defender Antivirus: disabled (AV)
11:48:32.070: Windows Firewall: enabled (FW)
11:48:32.070: Windows Defender Antivirus: disabled (ASW)
11:48:32.076: Portable mode: false
11:48:32.285: OBS 21.1.0 (64bit, windows)
11:48:32.285: ---------------------------------
11:48:32.287: ---------------------------------
11:48:32.287: audio settings reset:
11:48:32.287: samples per sec: 44100
11:48:32.287: speakers: 2
11:48:32.292: ---------------------------------
11:48:32.292: Initializing D3D11...
11:48:32.292: Available Video Adapters:
11:48:32.297: Adapter 1: NVIDIA GeForce GTX 1050 Ti
11:48:32.297: Dedicated VRAM: 4216324096
11:48:32.297: Shared VRAM: 4107118592
11:48:32.297: output 1: pos={0, 0}, size={1920, 1080}, attached=true
11:48:32.297: output 2: pos={1920, 0}, size={2560, 1080}, attached=true
11:48:32.297: Adapter 2: Intel(R) HD Graphics 630
11:48:32.297: Dedicated VRAM: 134217728
11:48:32.300: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 Ti (0)
11:48:32.790: D3D11 loaded successfully, feature level used: 45056
11:48:33.634: ---------------------------------
11:48:33.634: video settings reset:
11:48:33.634: base resolution: 1920x1080
11:48:33.634: output resolution: 1280x720
11:48:33.634: downscale filter: Bilinear
11:48:33.634: fps: 30/1
11:48:33.634: format: NV12
11:48:33.634: YUV mode: 601/Partial
11:48:33.639: Audio monitoring device:
11:48:33.639: name: Default
11:48:33.639: id: default
11:48:33.641: ---------------------------------
11:48:33.658: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
11:48:33.731: [CoreAudio encoder]: Adding CoreAudio AAC encoder
11:48:33.778: [AMF] AMF Test failed due to one or more errors.
11:48:33.778: Failed to initialize module 'enc-amf.dll'
11:48:33.893: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
11:48:33.895: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
11:48:33.895: (127)
11:48:33.895: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
11:48:33.910: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
11:48:33.928: [browser_source: 'Version: 1.31.0']
11:48:33.969: NVENC supported
11:48:34.042: Couldn't find VLC installation, VLC video source disabled
11:48:34.055: No blackmagic support
11:48:34.074: ---------------------------------
11:48:34.074: Loaded Modules:
11:48:34.074: win-wasapi.dll
11:48:34.074: win-mf.dll
11:48:34.074: win-dshow.dll
11:48:34.074: win-decklink.dll
11:48:34.074: win-capture.dll
11:48:34.074: vlc-video.dll
11:48:34.074: text-freetype2.dll
11:48:34.074: rtmp-services.dll
11:48:34.074: obs-x264.dll
11:48:34.074: obs-vst.dll
11:48:34.074: obs-transitions.dll
11:48:34.074: obs-text.dll
11:48:34.074: obs-qsv11.dll
11:48:34.074: obs-outputs.dll
11:48:34.074: obs-filters.dll
11:48:34.074: obs-ffmpeg.dll
11:48:34.074: obs-browser.dll
11:48:34.074: image-source.dll
11:48:34.074: frontend-tools.dll
11:48:34.074: enc-amf.dll
11:48:34.074: coreaudio-encoder.dll
11:48:34.075: ==== Startup complete ===============================================
11:48:34.143: All scene data cleared
11:48:34.143: ------------------------------------------------
11:48:34.213: WASAPI: Device 'Headset Earphone (ASTRO MixAmp Pro )' initialized
11:48:34.230: WASAPI: Device 'Headset Microphone (ASTRO MixAmp Pro )' initialized
11:48:34.239: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
11:48:34.284: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
11:48:34.389: ---------------------------------
11:48:34.389: [DShow Device: 'Video Capture Device 2'] settings updated:
11:48:34.389: video device: USB HD WEBCAM
11:48:34.389: video path: \\?\usb#vid_0408&pid_2020&mi_00#6&37b53136&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
11:48:34.389: resolution: 640x480
11:48:34.389: fps: 30.00 (interval: 333333)
11:48:34.389: format: YUY2
11:48:35.567: [window-capture: 'League'] update settings:
11:48:35.567: executable: LeagueClientUx.exe
11:48:35.722: [Top Donators 2] TextSource::CalculateTextSizes: MeasureString (non-wrapped) failed (2)
11:48:35.722: [Top Donators 2] TextSource::RemoveNewlinePadding: MeasureString (without newline) failed (2)
11:48:35.722: [Top Donators 2] TextSource::RemoveNewlinePadding: MeasureString (with newline) failed (2)
11:48:35.722: [Top Donators 2] TextSource::RenderText: graphics_bitmap.DrawString failed (2)
11:48:35.726: [New Donator 2] TextSource::CalculateTextSizes: MeasureString (non-wrapped) failed (2)
11:48:35.726: [New Donator 2] TextSource::RemoveNewlinePadding: MeasureString (without newline) failed (2)
11:48:35.726: [New Donator 2] TextSource::RemoveNewlinePadding: MeasureString (with newline) failed (2)
11:48:35.726: [New Donator 2] TextSource::RenderText: graphics_bitmap.DrawString failed (2)
11:48:35.734: warning: deprecated pixel format used, make sure you did set range correctly
11:48:35.737: Failed to open file 'C:/Stream/Sponsors/DIbannerMainsite-01.png': No such file or directory
11:48:35.737: gs_image_file_init: Failed to load file 'C:/Stream/Sponsors/DIbannerMainsite-01.png'
11:48:35.737: [image_source: '(null)'] failed to load texture 'C:/Stream/Sponsors/DIbannerMainsite-01.png'
11:48:35.768: Switched to scene 'In game'
11:48:35.777: ------------------------------------------------
11:48:35.777: Loaded scenes:
11:48:35.777: - scene 'In game':
11:48:35.779: - source: 'Game Capture' (game_capture)
11:48:35.779: - source: 'Image 3' (image_source)
11:48:35.779: - source: 'Image 4' (image_source)
11:48:35.779: - source: 'Video Capture Device 2' (dshow_input)
11:48:35.779: - source: 'Image 5' (image_source)
11:48:35.779: - source: 'Image 6' (image_source)
11:48:35.779: - source: 'Image 7' (image_source)
11:48:35.779: - filter: 'Color Correction' (color_filter)
11:48:35.779: - source: 'New Follower at the top' (image_source)
11:48:35.779: - source: 'New Follower 2' (text_gdiplus)
11:48:35.779: - source: 'Donation Alert' (browser_source)
11:48:35.779: - source: 'Chat' (browser_source)
11:48:35.779: - source: 'The Jar' (browser_source)
11:48:35.779: - source: 'Sponsors' (slideshow)
11:48:35.779: - source: 'Latest Donator Image' (image_source)
11:48:35.779: - source: 'New Donation 2' (text_gdiplus)
11:48:35.779: - scene 'Out of game':
11:48:35.779: - source: 'League' (window_capture)
11:48:35.779: - source: 'Image' (image_source)
11:48:35.779: - source: 'Top donators' (text_gdiplus)
11:48:35.779: - filter: 'Scroll' (scroll_filter)
11:48:35.779: - source: 'New Donation' (text_gdiplus)
11:48:35.779: - source: 'New Follower' (text_gdiplus)
11:48:35.779: - source: 'Twitch icon' (image_source)
11:48:35.779: - source: 'Youtube' (image_source)
11:48:35.779: - source: 'Jar' (browser_source)
11:48:35.779: - source: 'Twitch' (text_gdiplus)
11:48:35.779: - source: 'Youtube name' (text_gdiplus)
11:48:35.779: - scene 'Be right back':
11:48:35.779: - source: 'Be right back image' (image_source)
11:48:35.779: - source: 'New Donator 2' (text_gdiplus)
11:48:35.779: - source: 'New Follower 3' (text_gdiplus)
11:48:35.779: - source: 'Top Donators 2' (text_gdiplus)
11:48:35.779: - filter: 'Crop/Pad' (crop_filter)
11:48:35.779: - source: 'Top donators 2' (text_gdiplus)
11:48:35.779: ------------------------------------------------
