Question / Help I need some help with LGP Stream Engine.
o Diego z
Hey this is my 1st time on the forums,
When i start up LGP Stream Engine it says immediately ''Program stopped running'' in Windows 7 Pro.
I downloaded it already but deleted it because it didnt work by OBS now i know the problem but can't open LGP Stream Engine anymore. Hope you guys have some suggestions what the problem is. i tried to download it again, restore Windows when it worked fine and downloaded it again nohting worked so far.
- Diego
Sapiens
Forum Moderator
You need to contact AVerMedia for support with their software. Stream Engine crashing is not an OBS issue.
Jack0r
The Helping Squad
Apart of that I would do the usual, remove all software/drivers, unplug the device, reboot, replug the device, install the drivers/software again.
