OBS Studio creates a log file each time you run it which contains very useful diagnostic information. Without a log file, it's much harder for any support volunteers to figure out problems and your post may be ignored.
To upload a log file, go to the Help menu > Log Files > Upload Last Log File. "Last Log File" is for the last session (the last time you ran OBS). In some cases you may be asked to select "Current Log File" instead, which is for the current session.
Click on the "Copy URL" button to copy the link to your clipboard, then paste the link in your forum...
do you only have a single monitor? if yes, you can't run one application in Full Screen and see anything else... you are literally asking to NOT see anything else.
You don't need to see OBS Studio for it to operate... though it is nice to monitor what is going on. So OBS Studio can be in background and it work fine (presuming adequate compute resources for your settings)
BUT... if you want to change scenes, or otherwise interact with OBS Studio during recording then you have a couple of choices:
- ALT-TAB to OBS Studio, make change and switch back to Roblox... though probably not what you want (you'd want to practice so you are quick and good at this... and Recording needs to be Roblox Application window, not Desktop Screen as you'd record OBS Studio when you make it foreground application)
- use OBS Studio Hot Keys for its inputs (so OBS Studio can stay in background)
- use an external box (ex streamdeck) to automate some of your desired OBS Studio inputs
- get a second monitor
and I'm sure there are others... but the others are primary methods
