EpicKingdom_
First off, I have watched many videos and viewed many guides. A lot of them are not working for me. I'm not a streamer, I just want good quality and performance local recordings.
The only settings that I can make work are these.. although, I do not feel like they are right since sometimes I get fps dips in the video playback.
Settings:
Game capture.
2560x1440 @ 60fps.
Encoding:
Nvidia NVENC.
Use CBR = true.
Enable CBR padding = true.
Quality balance = 10.
Max bitrate = 75,000. (The higher, the better the quality is. Although, the higher the bigger the file size is).
Audio bitrate = 128.
Advanced:
Defaults except for..
NVENC Preset = high performance.
Video save path goes to a SSD.
Here is a test video with the settings above: https://www.youtube.com/watch?v=NZQ74ZR2Dks
It really doesn't matter what settings I have, if I EVER use x264 encoder my video playback lags or freezes while the audio remains. I've tried everything, low bitrate, high bitrate, unchecking CBR, changing quality balance, lowering FPS and resolution, setting crf anywhere from 0-20 etc..
(edit): A resolution downscale from 1440p to 1152 seems to fix everything... I would prefer not to downscale though. Is it my hardware or settings that cannot do 1440p @ 60fps?
https://gist.github.com/2713bce6f1aa36d8600f
Settings:
Game capture.
2560x1440 @ 60fps.
Encoding:
Nvidia NVENC.
Use CBR = true.
Advanced:
