I HAVE PROBLEMS WITH MY GTX 1070 and OBSBOT TINY 1 / TENGO PROBLEMAS CON MI GTX 1070 y OBSBOT TINY 1 /
donyojimbo
Recientemente cambie de gpu y cada vez que abro obs, el audio de la computadora comienza a entrecortarse y el video de la camara se muestra glitcheado, alguien sabe a que se debe esto?
I recently changed GPUs and every time I open obs, the audio from the computer starts to stutter and the video from the camera is glitched, does anyone know what causes this?
I hope you can help me, many thanks for your answer.
Donyojimbo, have a look at the output from the OBS Log Analyzer.
There are a number of things for you to correct/change. When you have done that please produce another log file after you have done 60 seconds of Streaming or Recording which ever of these you are doing. This will give people on the forum more information about your system and make it easier to diagnose.
There are a large amount of errors that indicate insufficient usb bandwidth. Make sure you connect your camera directly to your pc/laptop without any hub in between and you're using a proper cable that supports usb 2 or usb 3 speed (and the usb port at your computer as well).
