Question / Help I have an RTX 2070 max q and I get terrible quality when recording
CrustyPoo
I have tried lots of OBS tutorials and nothing works. I even made sure obs was using the right graphics card to record with. Then when I go to record anything with 1080p 60fps it comes out ugly and at like 30 fps. I would be so grateful if someone could fix this as I really want to start a Rainbox Six Seige youtube channel.
Here are my logs if it helps:
thank you
You set RGBA as format, and this format is "slow" and resource-intensive. It's the cause of your fps issues. Fast, optimized and standard is NV12. It's not just a cosmetic change, the performance difference of both formats is significant.
yes, I just noticed this thank you a lot!!!!
is there anything else I can do to boost even more?
