Question / Help I have a problem, please HELP!
Elizockt
When i will recording there stand:
"Could not initialize DirectX 10 on RADEON X800 Series. THis error can happen for one of the following reasons:
1.) Your GPU is nor supported (DirectX 10 is required - note that many integrated laptop GPUs do not support DX10)
2.) You're running Windows Vista without the "Platform Update"
3.) Your Video card drivers are out of date.
If you are using a laptop with NVIDIA Optimus or AMD Switchable Graphics, make sure OBS is set to run on the high performance GPU in you driver Settings"
Your graphics card does not support DirectX 10. OBS uses DirectX 10
http://en.wikipedia.org/wiki/Radeon_X800_Series (under Rendering support it only lists DX9/Direct3D9)
You'll need a new graphics card to use OBS, or hope the OBS rewrite will not require DX10. But there's no time estimate till that gets released.
(also I wasn't aware windows 7 worked with graphics cards that cannot DX10. Remember windows XP doesn't support DX10 either, so you need at least vista)
Buy a new graphics card. Or try xsplit, I think it runs without dx10. But xsplit isn't free, I guess the trial mode is decent though.
