JunkyVirus
Hi, so I've posted about this problem before but sadly no one has been able to help me with my problem.
I can stream fine, that is no problem whatsoever with the sound, but when I try to put a facecam in the sound get all weird, to me it kind of sound like an old shitty blown out speaker, but I know that's not the problem, cuz then it would always sound like that.
Also the FPS seem to be pretty bad for some reason when I have the cam on, frame drops and lags.
I streamed a little video "showing" the problem, first with the cam on so you hear it, then a bit later I turn it off so you can see or hear that it's all good after that.
http://www.youtube.com/watch?v=40L2cyzTZ2o
You can start the video at about 2:20 min and you'll get an instant impression, I would really like to know what's wrong, I love OBS and the streaming is so good, but this is a real problem for me.
09:57:39: Open Broadcaster Software v0.542b - 64bit ( ^ω^)
09:57:39: -------------------------------
09:57:39: CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
09:57:39: CPU Speed: 3500MHz
09:57:39: Physical Memory: 8136MB Total, 5995MB Free
09:57:39: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
09:57:39: monitor 1: pos={0, 0}, size={1920, 1080}
09:57:39: monitor 2: pos={1920, 0}, size={1920, 1080}
09:57:39: Windows Version: 6.1 Build 7601 S
09:57:39: Aero is Enabled
09:57:39: OBS Modules:
09:57:39: Base Address Module
09:57:39: 000000003F880000 OBS.exe
09:57:39: 00000000F1000000 OBSApi.dll
09:57:39: 00000000FB1B0000 DShowPlugin.dll
09:57:39: 00000000F9790000 GraphicsCapture.dll
09:57:39: 00000000F9770000 NoiseGate.dll
09:57:39: 00000000F9750000 PSVPlugin.dll
09:57:39: ------------------------------------------
09:57:39: Adapter 1
09:57:39: Video Adapter: AMD Radeon HD 6800 Series
09:57:39: Video Adapter Dedicated Video Memory: 1060859904
09:57:39: Video Adapter Shared System Memory: 3997616128
09:57:39: =====Stream Start: 2013-07-27, 09:57:39===============================================
09:57:39: Multithreaded optimizations: On
09:57:39: Base resolution: 1920x1080
09:57:39: Output resolution: 1920x1080
09:57:39: Loading up D3D10...
09:57:39: Playback device {0.0.0.00000000}.{424dd2c7-5e77-4fb0-a878-ca8344ca8c62}
09:57:39: Using desktop audio input: Plantronics (4- Plantronics GameCom 780)
09:57:39: Using auxilary audio input: Mikrofon (Yeti Stereo Microphone)
09:57:39: Audio Encoding: AAC
09:57:39: bitrate: 192
09:57:39: device: Logitech HD Webcam C615,
09:57:39: device id \\?\usb#vid_046d&pid_082c&mi_02#6&b3bf97f&1&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
09:57:39: chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
09:57:39: audio device: Mikrofon (Yeti Stereo Microphon,
09:57:39: audio device id (null),
09:57:39:
09:57:39: device audio info - bits per sample: 16, channels: 2, samples per sec: 44100, block size: 4
09:57:39: Using directshow input
09:57:40: Using bitmap image
09:57:40: Using graphics capture
09:57:40: Using custom x264 settings: "keyint=60"
09:57:40: ------------------------------------------
09:57:40: Video Encoding: x264
09:57:40: fps: 30
09:57:40: width: 1920, height: 1080
09:57:40: preset: veryfast
09:57:40: CBR: yes
09:57:40: CFR: no
09:57:40: max bitrate: 7000
09:57:43: SO_SNDBUF was at 8192
09:57:43: SO_SNDBUF is now 65536
09:58:22: SharedTexCapture hooked
10:03:01: Total frames rendered: 9610, number of frames that lagged: 63 (0.66%) (it's okay for some frames to lag)
10:03:03: RTMPPublisher::SocketLoop: Aborting due to bStopping
10:03:03: Number of times waited to send: 0, Waited for a total of 0 bytes
10:03:03: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
10:03:03: =====Stream End: 2013-07-27, 10:03:03=================================================
10:03:04: =====Stream Start: 2013-07-27, 10:03:04===============================================
10:03:04: Multithreaded optimizations: On
10:03:04: Base resolution: 1920x1080
10:03:04: Output resolution: 1920x1080
10:03:04: ------------------------------------------
10:03:04: Loading up D3D10...
10:03:04: Playback device {0.0.0.00000000}.{424dd2c7-5e77-4fb0-a878-ca8344ca8c62}
10:03:04: Using desktop audio input: Plantronics (4- Plantronics GameCom 780)
10:03:04: Using auxilary audio input: Mikrofon (Yeti Stereo Microphone)
10:03:04: Audio Encoding: AAC
10:03:04: bitrate: 192
10:03:04: Using bitmap image
10:03:04: Using graphics capture
10:03:04: Using custom x264 settings: "keyint=60"
10:03:04: Video Encoding: x264
10:03:04: fps: 30
10:03:04: width: 1920, height: 1080
10:03:04: preset: veryfast
10:03:04: CBR: yes
10:03:04: CFR: no
10:03:04: max bitrate: 7000
10:03:04: SharedTexCapture hooked
10:03:08: SO_SNDBUF was at 8192
10:03:08: SO_SNDBUF is now 65536
10:05:59: Total frames rendered: 5230, number of frames that lagged: 6 (0.11%) (it's okay for some frames to lag)
10:06:00: RTMPPublisher::SocketLoop: Aborting due to bStopping
10:06:00: Number of times waited to send: 0, Waited for a total of 0 bytes
10:06:00: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
10:06:01: =====Stream End: 2013-07-27, 10:06:01=================================================
10:18:02:
10:18:02: Profiler results:
10:18:02:
10:18:02: ==============================================================
10:18:02: frame - [100%] [avg time: 6.63 ms (cpu time: avg 5.472 ms, total 81214.1 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.106%]
10:18:02: | frame preprocessing and rendering - [32.8%] [avg time: 2.177 ms (cpu time: avg 1.739 ms, total 25818.2 ms)] [avg calls per frame: 1] [children: 21.9%] [unaccounted: 10.9%]
10:18:02: | | scene->Preprocess - [21.9%] [avg time: 1.452 ms (cpu time: avg 1.333 ms, total 19796.6 ms)] [avg calls per frame: 1]
10:18:02: | video encoding and uploading - [67.1%] [avg time: 4.446 ms (cpu time: avg 3.73 ms, total 55364.7 ms)] [avg calls per frame: 1] [children: 65%] [unaccounted: 2.07%]
10:18:02: | | flush - [7.15%] [avg time: 0.474 ms (cpu time: avg 0.052 ms, total 780.003 ms)] [avg calls per frame: 1]
10:18:02: | | CopyResource - [0.271%] [avg time: 0.018 ms (cpu time: avg 0.008 ms, total 124.8 ms)] [avg calls per frame: 0]
10:18:02: | | conversion to 4:2:0 - [0.121%] [avg time: 0.008 ms (cpu time: avg 0.006 ms, total 93.601 ms)] [avg calls per frame: 0]
10:18:02: | | call to encoder - [55.7%] [avg time: 3.694 ms (cpu time: avg 3.555 ms, total 52759.5 ms)] [avg calls per frame: 0]
10:18:02: | | sending stuff out - [1.73%] [avg time: 0.115 ms (cpu time: avg 0.079 ms, total 1185.61 ms)] [avg calls per frame: 0]
10:18:02: | Convert444Threads - [1.01e+003%] [avg time: 66.703 ms (cpu time: avg 3.528 ms, total 52369.5 ms)] [avg calls per frame: 1]
10:18:02:
09:57:39: Adapter 1
09:57:39:
09:57:40: fps: 30
09:57:40: CBR: yes
09:57:40: CFR: no
10:03:04: fps: 30
10:03:04: CBR: yes
10:03:04: CFR: no
10:18:02:
10:18:02:
10:18:02:
