Hi all
I am familiar with Audio Hijack on macOS or Voice Meter Banana on Windows but would like to use OBS instead.
Particularly for faculty and departments with low funding (Covid-19) this would be a great cost effective and platform similar approach.
I spent the past few weeks trying to figure out how
But it seems not to work.
This is what I did:
could any body help me what I am doing wrong?
I assume with OBS and Virtual Cable the settings in OBS in windows is the same
- in OBS capture the mic audio
- adjust it via sound effects (noise gate etc)
- send the audio to VB virtual cable
- use that modified audio in Zoom.
This is what I did:
- I installed the VB Cable (https://vb-audio.com/Cable/)
- I installed OBS
- I added an audio input device (mic)
- Set the OBS voice meter to VB Virtual cable
- Set Zoom / Screencastify (recording) mic to VB cable
