How to trasfer all OBS studio’s current saved presets and settings from my PC to a USB drive and then to another PC without setting everything again
ROCCO80
Hi All
I would like to know where I can find in my PC all saved presets and settings of my OBS's studio so as to transfer everything to a USB drive and then to another PC in a way that when I install it in the new PC, I will avoid setting up everything again. Therefore, by doing so, I will be able to install OBS studio with all the saved presets and settings and use them instantly the same way as I’m doing now in my old PC. Is there a way to do that?
At the top menu select Profile then Export
Do the same with Scene Collection
You need to copy over the overlays to the USB stick as well.
When you import the profile and scenes it will as where the overlays are stored.
There will always be some stuff you need to edit. For me it's the audio sources.
