General
Complete name : D:\Dateien\Allgemein\Video\Aufzeichnungen\2020-10-06 11-17-14.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 754 MiB
Duration : 8 s 341 ms
Overall bit rate : 759 Mb/s
Writing application : Lavf58.29.100
Video
Format : RGB
Codec ID : ULRG
Codec ID/Info : Ut Video Lossless Codec
Codec ID/Hint : Ut Video
Duration : 8 s 333 ms
Bit rate : 758 Mb/s
Width : 2 560 pixels
Height : 1 440 pixels
Display aspect ratio : 16:9
Frame rate : 60.000 FPS
Color space : RGB
Bit depth : 8 bits
Bits/(Pixel*Frame) : 3.426
Stream size : 753 MiB (100%)
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 1.53 MiB (0%)
Alignment : Aligned on interleaves
Interleave, duration : 21 ms (1.28 video frame)
