How to record in Stereo using Behringer UCA202.
fogroach
Hi all,
I purposely bought the Behringer UCA202 so that I could record/stream with a stereo signal, as I send a stereo signal from my mixer. I have set up this device as the mic/aux on OBS Studio but I still only see a single channel on the audio view, so it is only recording in Mono.
What am I doing wrong here? If I go to the cog settings of that audio it makes no change if i select or deselect the mono box. Is this a limitation with my onboard soundcard perhaps. (I notice when I use the default laptop mic on my laptop it comes up as a stereo sginal on OBS).
Got it!
It was in the hardware options of the Berhinger USB device in Control Panel. It was set to one channel and not 2. Hope this helps anyone else!
I just registered to the forum to say thank you! I'll try it tomorrow, I've been struggling with this for a while :D
Probably I'll have my test results sooner, but: was it still actually two separate channels? once I got it to recognize as stereo but it was just still a mono signal duplicated to 2 channels.
