how to fix "server connection problem" error
x_coppynay
do exactly what the message says, make sure that you have all of the streaming server information correct in OBS. verify that your stream key and stream service is all correct. or if using a connected account, disconnect and reconnect the account. and if all of that is correct, then it is possible that the streaming service is having connection issues.
I am having same issue was streaming earlier and 2 hours later cant, Twitch starts just fine, but Facebook wont!!! i need help as well!!!
i was curious... i can connect and stream to FB without issue. double check your stream key. but it is also possible that they fixed the issue already.
