Videophile
Elgato
LtRoyalShrimp submitted a new resource:
How to eliminate static/ground issues when using mixers - How to eliminate static/ground issues when using mixers
Read more about this resource...
So, your using a mixer, and you notice a loud and irritating buzzing, humming, or otherwise not-supposed-to-be-there-sound.
Well, what you may be running into is a grounding issue.
There are two ways to solve this, and using both is the best way.
The first way is to use a ground loop isolator. Now the connection from your PC to your mixer will probably be a 3.5mm(1/8") to TRS stereo cable.
What you will want to use is a...
