Question / Help How much upload speed required to stream?
vwey
DANG!! thats a lot. so happy i got new internet. Before i was streaming with 400kbps now i have 11420!? what is the max upload speed i can input for twitch?
vwey
well i got the 50d/10u package deal for 35$/month for 1 year new member so i bought that. is it still advisable to still have minimize network impact check? i used it when i was streaming with 400kbps
no, you should be fine.
With anywhere from 3 to 5 Megabits being used as your stream bandwidth, that still leaves you with 5 - 7 megabits for other things on your network, including the broadcasting computer, to make use of.
Minimize Network Impact is mainly a Quality of Service option. You wont be maxing out your main internet bandwidth with a broadcast, so you'll be fine.
pro-tip: you can adjust the amount of bandwidth your stream is using WHILE broadcasting to twitch. start at 3, open the stream in another window or on a laptop, phone, whatever, and see how it looks. then pop it up to 4, then to 5, and see the quality difference
keep in mind, however, that just because you can send at 5 doesnt mean people who watch your stream want to download 5. I broadcast at 2 Megabits on average, and I have a lot of viewers that say they have a lot of buffering issues. this is a problem WITH Twitch specifically, not the viewer or the broadcaster
vwey
i used the estimator and it recommend me to use 3500 kbps so i'm going to use that. is it sufficient enough of should i go lower or higher? yes i know some people have buffering issue so should i stay at 3500 or lower? most streamers use 3500 right?
harryhp101
Yeah...
