Question / Help How get sound with Avermedia capture HD 727
Javierc
Hi, when I add the source for my PCI Avermedia capture HD 727 I select the device AverMedia BDA Analog capture Secondary and show the video perfect, but only show video, I try get the audio adding source for audio withe source Audio Input Capture only have three options so not have the correct sound for there:
- Default
- Microphone (HD Webcam C270)
- Microphone (Device hight definition audio)
- Line in (device high definition audio)
In the source options for Audio output capture
-Default
- Audio digitial (HDMI device high definiticion audio ) -> this is from motheboard not avermedia capture
- Speakers (device hight definition audio)
- Audio digitial (S/PDIF) (Device high definition audio)
Changing the option propierties- Audio Output Mode to Output desiktop audio( Direct sound or waveout) only hear noise of the analgo TV tunner from the card.
Exist any way to get the the sound also?
The log is https://gist.github.com/a912643d28282c7fd9e339884e8819b8
Regards
