How do I use Quicksync when using Custom Output (FFmpeg)?
BCN-Dude
Hi
I am streaming my screen to another computer using the UDP and MPEG-TS method.
It works great, but however the CPU usage is a bit high for my Core I3.
Quick sync works great for regular streaming, however, for some reason I cannot find it in the encoder
list when i am using the Output to URL option in the recording tab.
I notice there is a video encoder settings field in the section, am I supposed to enable it from there?
If yes, what is the text I must input?
Thanks,
NDI might be better suited for your use case.
I have tried NDI, it takes up too much bandwidth.
The stream is over a wireless point to point link that is 2km in distance.
Only got 60mbps of bandwidth. I would love to use NDI but it's just not great over wireless.
UDP/MPEG-TS works wonders though.
