Hotkeys not saving after a restart using OBS studio
Phoenix_025
Currently I'm running OBS studio, but every time I close down the programme and run it again the hotkeys I saved previously have not been remembered.
Ill post 2 logs, one where I have saved all the hotkeys and then one on a restart that is showing them not saved.
Log 1
Started with Enable/Disable Phone Blur empty and changed it to Enable F2 and Disable ESC
Log 2
Hotkeys for Enable /Disable Phone blur are currently empty again
Any help is appreciated.
is it only these blur hotkeys or all hotkeys? for example if you were to set a hotkey for something built into OBS like starting and stopping a recording?
