Question / Help High Upload Speed/Low Max Bitrate
Gasmic
Hello everyone!
I'm having trouble streaming!
My computer specs are:
i7 2.80GHz
16GB RAM DDR3
Radeon HD5700
18GB Download Speed
5GB Upload Speed
My current stream has currently blurs out a lot of motion even when I'm getting high FPS in-game and on OBS.
My settings on OBS are:
1680x1050
30FPS
x264 Preset: Faster
Quality Balance: 7
Max Bitrate: 1200
According to my research, I should be able to increase my max bit-rate to 3500 which should solve my problem... but whenever I increase it to over 1200 I start dropping frames.
My FPS in-game and OBS is completely fine... the frames just start dropping over the stream.
I'm trying to link GW2 on twitch.tv.
A link to my stream is: www.twitch.tv/ohhhgasm
Gasmic
I did all of that and I'm still having a large amount of blurring when my character is in motion.
Kharay
Could you please post a log (found in %AppData%\OBS\logs) as well the results for the test you took at Testmy.net?
Gasmic
Download :: 17.9 Mbps up arrow Upload :: 1.3 Mbps
Log:
04:56:07: Open Broadcaster Software v0.542b - 64bit ( ^ω^)
04:56:07: -------------------------------
04:56:07: CPU Name: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
04:56:07: CPU Speed: 2807MHz
04:56:07: Physical Memory: 16375MB Total, 12755MB Free
04:56:07: stepping id: 5, model 14, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
04:56:07: monitor 1: pos={0, 0}, size={1680, 1050}
04:56:07: Windows Version: 6.1 Build 7601 S
04:56:07: Aero is Enabled
04:56:07: OBS Modules:
04:56:07: Base Address Module
04:56:07: 000000003F690000 OBS.exe
04:56:07: 00000000E7020000 OBSApi.dll
04:56:07: 00000000FAA60000 DShowPlugin.dll
04:56:07: 00000000FAA30000 GraphicsCapture.dll
04:56:07: 00000000F7C30000 NoiseGate.dll
04:56:07: 00000000FC570000 PSVPlugin.dll
04:56:07: ------------------------------------------
04:56:07: Adapter 1
04:56:07: Video Adapter: ATI Radeon HD 5700 Series
04:56:07: Video Adapter Dedicated Video Memory: 1054703616
04:56:07: Video Adapter Shared System Memory: 4021874688
04:56:07: =====Stream Start: 2013-08-05, 04:56:07===============================================
04:56:07: Multithreaded optimizations: On
04:56:07: Base resolution: 1680x1050
04:56:07: Output resolution: 1120x700
04:56:07: Loading up D3D10...
04:56:07: Playback device Default
04:56:07: Using desktop audio input: Speakers (High Definition Audio Device)
04:56:07: Using auxilary audio input: Microphone (HD Webcam C270)
04:56:07: Audio Encoding: AAC
04:56:07: bitrate: 128
04:56:07: Using graphics capture
04:56:07: Video Encoding: x264
04:56:07: fps: 30
04:56:07: width: 1120, height: 700
04:56:07: preset: veryfast
04:56:07: CBR: yes
04:56:07: CFR: no
04:56:07: max bitrate: 3500
04:56:11: Total frames rendered: 128, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
04:56:12: =====Stream End: 2013-08-05, 04:56:12=================================================
04:56:24: =====Stream Start: 2013-08-05, 04:56:24===============================================
04:56:24: Multithreaded optimizations: On
04:56:24: Base resolution: 1680x1050
04:56:24: Output resolution: 1120x700
04:56:24: ------------------------------------------
04:56:24: Loading up D3D10...
04:56:24: Playback device Default
04:56:24: Using desktop audio input: Speakers (High Definition Audio Device)
04:56:24: Using auxilary audio input: Microphone (HD Webcam C270)
04:56:24: Audio Encoding: AAC
04:56:24: bitrate: 128
04:56:24: Using graphics capture
04:56:25: ------------------------------------------
04:56:25: Video Encoding: x264
04:56:25: fps: 30
04:56:25: width: 1120, height: 700
04:56:25: preset: veryfast
04:56:25: CBR: yes
04:56:25: CFR: no
04:56:25: max bitrate: 3500
04:56:25: SharedTexCapture hooked
04:56:30: Total frames rendered: 169, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
04:56:30: =====Stream End: 2013-08-05, 04:56:30=================================================
04:56:31: =====Stream Start: 2013-08-05, 04:56:31===============================================
04:56:31: Multithreaded optimizations: On
04:56:31: Base resolution: 1680x1050
04:56:31: Output resolution: 1120x700
04:56:31: ------------------------------------------
04:56:31: Loading up D3D10...
04:56:31: Playback device Default
04:56:31: Using desktop audio input: Speakers (High Definition Audio Device)
04:56:31: Using auxilary audio input: Microphone (HD Webcam C270)
04:56:31: Audio Encoding: AAC
04:56:31: bitrate: 128
04:56:31: Using graphics capture
04:56:31: Video Encoding: x264
04:56:31: fps: 30
04:56:31: width: 1120, height: 700
04:56:31: preset: veryfast
04:56:31: CBR: yes
04:56:31: CFR: no
04:56:31: max bitrate: 3500
04:56:31: SharedTexCapture hooked
04:56:33: Connection to (null) failed: No server specified to connect to
04:56:33: Total frames rendered: 57, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
04:56:33: Number of times waited to send: 0, Waited for a total of 0 bytes
04:56:33: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
04:56:33: =====Stream End: 2013-08-05, 04:56:33=================================================
04:59:01: =====Stream Start: 2013-08-05, 04:59:01===============================================
04:59:01: Multithreaded optimizations: On
04:59:01: Base resolution: 1680x1050
04:59:01: Output resolution: 1120x700
04:59:01: ------------------------------------------
04:59:01: Loading up D3D10...
04:59:01: Playback device Default
04:59:01: Using desktop audio input: Speakers (High Definition Audio Device)
04:59:01: Using auxilary audio input: Microphone (HD Webcam C270)
04:59:01: Audio Encoding: AAC
04:59:01: bitrate: 128
04:59:01: Using graphics capture
04:59:01: Video Encoding: x264
04:59:01: fps: 30
04:59:01: width: 1120, height: 700
04:59:01: preset: veryfast
04:59:01: CBR: yes
04:59:01: CFR: no
04:59:01: max bitrate: 3500
04:59:01: SharedTexCapture hooked
04:59:04: Using RTMP service: Twitch / Justin.tv
04:59:04: Server selection: rtmp://live.justin.tv/app
04:59:05: SO_SNDBUF was at 8192
04:59:05: SO_SNDBUF is now 65536
04:59:15: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
05:00:09: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
05:00:23: Total frames rendered: 2442, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
05:00:24: okay, this is strange
05:00:24: RTMPPublisher::SocketLoop: Aborting due to loop exit
05:00:24: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
05:00:24: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
05:00:24: Number of times waited to send: 28, Waited for a total of 99135 bytes
05:00:24: Number of b-frames dropped: 752 (32%), Number of p-frames dropped: 741 (31%), Total 1493 (63%)
05:00:25: =====Stream End: 2013-08-05, 05:00:25=================================================
05:02:16:
05:02:16: Profiler results:
05:02:16:
05:02:16: ==============================================================
05:02:16: frame - [100%] [avg time: 1.955 ms (cpu time: avg 1.562 ms, total 4368.03 ms)] [avg calls per frame: 1] [children: 99.7%] [unaccounted: 0.256%]
05:02:16: | frame preprocessing and rendering - [22.8%] [avg time: 0.445 ms (cpu time: avg 0.251 ms, total 702.002 ms)] [avg calls per frame: 1] [children: 0.0512%] [unaccounted: 22.7%]
05:02:16: | | scene->Preprocess - [0.0512%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
05:02:16: | video encoding and uploading - [77%] [avg time: 1.505 ms (cpu time: avg 1.311 ms, total 3666.03 ms)] [avg calls per frame: 1] [children: 75.5%] [unaccounted: 1.48%]
05:02:16: | | flush - [10.8%] [avg time: 0.212 ms (cpu time: avg 0.039 ms, total 109.2 ms)] [avg calls per frame: 1]
05:02:16: | | CopyResource - [0.409%] [avg time: 0.008 ms (cpu time: avg 0.022 ms, total 62.401 ms)] [avg calls per frame: 0]
05:02:16: | | conversion to 4:2:0 - [0.767%] [avg time: 0.015 ms (cpu time: avg 0.011 ms, total 31.2 ms)] [avg calls per frame: 0]
05:02:16: | | call to encoder - [61.9%] [avg time: 1.21 ms (cpu time: avg 1.177 ms, total 3291.62 ms)] [avg calls per frame: 0]
05:02:16: | | sending stuff out - [1.59%] [avg time: 0.031 ms (cpu time: avg 0.055 ms, total 156.001 ms)] [avg calls per frame: 0]
05:02:16: | Convert444Threads - [3.33e+003%] [avg time: 65.043 ms (cpu time: avg 1.573 ms, total 4399.22 ms)] [avg calls per frame: 1]
05:02:16:
So it seems that my upload speed is lower than what I initially thought.
Is there anything I can do still to improve the quality of my stream?
alpinlol
i hope you choose the nearest server to you on trestmynet ...
so whatever you are limited due to your upload right now usually high motion games get a really nice quality with 720@30 at around 2500-3000 bitrate but you gotta live with the quality loss thats whats happening when you are live encoding you either drop frames due to hight bitrate your upload cant handle (streams lagging) or you lose quality with a low bitrate but your upload is able to manage it (stream looks blurry and grainy)
