Question / Help HI, need help guys Laptop obs
dizzin
Hi guys
I have a laptop msi ge63 raider
1070
16 GB
i7
I run obs
I select the window in the game and the game itself Dota 2
In obs, the game takes 10-15 seconds
And then it stops completely and nothing happens.
But the game is fully working.
And in obs everything stopped
How do i solve this problem?
I do not have a black screen, I just stop the game in obs
Logs
12:16:49.401: CPU Name: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
12:16:49.401: CPU Speed: 2208MHz
12:16:49.401: Physical Cores: 6, Logical Cores: 12
12:16:49.401: Physical Memory: 16227MB Total, 10556MB Free
12:16:49.401: Windows Version: 10.0 Build 17763 (revision: 253; 64-bit)
12:16:49.401: Running as administrator: false
12:16:49.401: Aero is Enabled (Aero is always on for windows 8 and above)
12:16:49.401: Windows 10 Gaming Features:
12:16:49.401: Game DVR: On
12:16:49.402: Sec. Software Status:
12:16:49.404:
12:16:49.404: Current Date/Time: 2019-06-06, 12:16:49
12:16:49.405: Browser Hardware Acceleration: true
12:16:49.405: Portable mode: false
12:16:49.838: OBS 23.1.0 (64-bit, windows)
12:16:49.838: ---------------------------------
12:16:49.838: audio settings reset:
12:16:49.838: samples per sec: 44100
12:16:49.838: speakers: 2
12:16:49.839: ---------------------------------
12:16:49.839: Initializing D3D11...
12:16:49.839: Available Video Adapters:
12:16:49.844: Adapter 1: Intel(R) UHD Graphics 630
12:16:49.844: Dedicated VRAM: 134217728
12:16:49.844: Shared VRAM: 4212957184
12:16:49.844: output 1: pos={0, 0}, size={1920, 1080}, attached=true
12:16:49.844: Adapter 2: NVIDIA GeForce GTX 1070
12:16:49.844: Dedicated VRAM: 4178575360
12:16:49.849: Loading up D3D11 on adapter Intel(R) UHD Graphics 630 (0)
12:16:49.862: D3D11 loaded successfully, feature level used: 45056
12:16:50.546: ---------------------------------
12:16:50.546: video settings reset:
12:16:50.546: base resolution: 1920x1080
12:16:50.546: output resolution: 1280x720
12:16:50.546: downscale filter: Bicubic
12:16:50.546: fps: 30/1
12:16:50.546: format: NV12
12:16:50.546: YUV mode: 601/Partial
12:16:50.546: NV12 texture support enabled
12:16:50.547: Audio monitoring device:
12:16:50.547: name: По умолчанию
12:16:50.547: id: default
12:16:50.547: ---------------------------------
12:16:50.549: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
12:16:50.550: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
12:16:50.577: [AMF] AMF Test failed due to one or more errors.
12:16:50.578: Failed to initialize module 'enc-amf.dll'
12:16:50.587: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
12:16:50.589: [obs-browser]: Version 2.3.1
12:16:50.589: [obs-browser]: Blacklisted device detected, disabling browser source hardware acceleration.
12:16:50.591: NVENC supported
12:16:50.605: Couldn't find VLC installation, VLC video source disabled
12:16:50.614: No blackmagic support
12:16:50.617: ---------------------------------
12:16:50.617: Loaded Modules:
12:16:50.617: win-wasapi.dll
12:16:50.617: win-mf.dll
12:16:50.617: win-ivcam.dll
12:16:50.618: win-dshow.dll
12:16:50.618: win-decklink.dll
12:16:50.618: win-capture.dll
12:16:50.618: vlc-video.dll
12:16:50.618: text-freetype2.dll
12:16:50.618: rtmp-services.dll
12:16:50.618: obs-x264.dll
12:16:50.618: obs-vst.dll
12:16:50.618: obs-transitions.dll
12:16:50.618: obs-text.dll
12:16:50.618: obs-qsv11.dll
12:16:50.618: obs-outputs.dll
12:16:50.618: obs-filters.dll
12:16:50.618: obs-ffmpeg.dll
12:16:50.618: obs-browser.dll
12:16:50.618: image-source.dll
12:16:50.618: frontend-tools.dll
12:16:50.618: enc-amf.dll
12:16:50.618: decklink-ouput-ui.dll
12:16:50.618: coreaudio-encoder.dll
12:16:50.618: ---------------------------------
12:16:50.618: ==== Startup complete ===============================================
12:16:50.618: Service '' not found
12:16:50.620: All scene data cleared
12:16:50.620: ------------------------------------------------
12:16:50.787: WASAPI: Device 'Динамики (Realtek(R) Audio)' initialized
12:16:51.004: WASAPI: Device 'Микрофон (Realtek(R) Audio)' initialized
12:16:51.004: Switched to scene 'Сцена'
12:16:51.004: ------------------------------------------------
12:16:51.004: Loaded scenes:
12:16:51.004: - scene 'Сцена':
12:16:51.055: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
12:16:51.055:
12:16:54.647: User added scene 'Сцена 2'
12:16:54.649: User switched to scene 'Сцена 2'
12:17:11.148: User added source 'Захват игры' (game_capture) to scene 'Сцена 2'
12:17:14.348: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:17:14.350: [game-capture: 'Захват игры'] using helper (compatibility hook)
12:17:14.353: [game-capture: 'Захват игры'] hook not loaded yet, retrying..
12:17:16.381: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:17:16.461: [game-capture: 'Захват игры'] d3d9 shared texture capture successful
12:17:16.482: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:17:16.482: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:17:16.483: [game-capture: 'Захват игры'] capture stopped
12:17:20.414: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:17:20.447: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:17:20.447: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:17:20.448: [game-capture: 'Захват игры'] capture stopped
12:17:24.448: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:17:24.481: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:17:24.481: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:17:24.481: [game-capture: 'Захват игры'] capture stopped
12:17:28.481: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:17:28.514: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:17:28.514: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:17:28.514: [game-capture: 'Захват игры'] capture stopped
12:17:31.242: User switched to scene 'Сцена'
12:17:31.690: User switched to scene 'Сцена 2'
12:17:31.715: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:17:31.747: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:17:31.747: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:17:31.748: [game-capture: 'Захват игры'] capture stopped
12:17:34.859: User switched to scene 'Сцена'
12:17:34.859: User Removed scene 'Сцена 2'
12:17:40.632: User added source 'Захват игры' (game_capture) to scene 'Сцена'
12:18:13.149: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:18:13.151: [game-capture: 'Захват игры'] using helper (compatibility hook)
12:18:13.152: [game-capture: 'Захват игры'] hook not loaded yet, retrying..
12:18:15.182: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:18:15.254: [game-capture: 'Захват игры'] d3d9 shared texture capture successful
12:18:15.281: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:18:15.281: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:18:15.281: [game-capture: 'Захват игры'] capture stopped
12:18:19.149: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:18:19.181: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:18:19.181: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:18:19.181: [game-capture: 'Захват игры'] capture stopped
12:18:21.181: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:18:21.214: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:18:21.214: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:18:21.214: [game-capture: 'Захват игры'] capture stopped
12:18:24.375: User Removed source 'Захват игры' (game_capture) from scene 'Сцена'
12:18:28.107: User added source 'Захват игры' (game_capture) to scene 'Сцена'
12:18:32.181: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:18:32.214: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:18:32.214: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:18:32.214: [game-capture: 'Захват игры'] capture stopped
12:18:36.217: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:18:36.247: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:18:36.247: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:18:36.248: [game-capture: 'Захват игры'] capture stopped
12:18:40.248: [game-capture: 'Захват игры'] attempting to hook process: dota2.exe
12:18:40.281: gs_texture_open_shared (D3D11): Failed to open shared 2D texture (80070057)
12:18:40.281: [game-capture: 'Захват игры'] init_shtex_capture: failed to open shared handle
12:18:40.281: [game-capture: 'Захват игры'] capture stopped
12:18:45.606: User Removed source 'Захват игры' (game_capture) from scene 'Сцена'
12:18:52.859: ==== Shutting down ==================================================
12:18:52.861: Switched to scene '(null)'
12:18:52.862: WASAPI: Device 'Динамики (Realtek(R) Audio)' Terminated
12:18:52.874: WASAPI: Device 'Микрофон (Realtek(R) Audio)' Terminated
12:18:52.883: All scene data cleared
12:18:52.883: ------------------------------------------------
12:18:52.922: Freeing OBS context data
12:18:52.939: [Scripting] Total detached callbacks: 0
12:18:52.948: == Profiler Results =============================
12:18:52.948: run_program_init: 1844.67 ms
12:18:52.948: ┣OBSApp::AppInit: 35.94 ms
12:18:52.948: ┃ ┗OBSApp::InitLocale: 1.553 ms
12:18:52.948: ┗OBSApp::OBSInit: 1701 ms
12:18:52.948: ┣obs_startup: 3.678 ms
12:18:52.948: ┗OBSBasic::OBSInit: 1263.52 ms
12:18:52.948: ┣OBSBasic::InitBasicConfig: 0.318 ms
12:18:52.948: ┣OBSBasic::ResetAudio: 0.134 ms
12:18:52.948: ┣OBSBasic::ResetVideo: 708.819 ms
12:18:52.948: ┣OBSBasic::InitOBSCallbacks: 0.005 ms
12:18:52.948: ┣OBSBasic::InitHotkeys: 0.039 ms
12:18:52.948: ┣obs_load_all_modules: 70.018 ms
12:18:52.948: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.38 ms
12:18:52.948: ┃ ┣obs_init_module(decklink-ouput-ui.dll): 0.263 ms
12:18:52.948: ┃ ┣obs_init_module(enc-amf.dll): 26.315 ms
12:18:52.948: ┃ ┣obs_init_module(frontend-tools.dll): 3.898 ms
12:18:52.948: ┃ ┣obs_init_module(image-source.dll): 0.003 ms
12:18:52.948: ┃ ┣obs_init_module(obs-browser.dll): 0.254 ms
12:18:52.948: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.587 ms
12:18:52.948: ┃ ┃ ┗nvenc_check: 0.557 ms
12:18:52.948: ┃ ┣obs_init_module(obs-filters.dll): 0.009 ms
12:18:52.948: ┃ ┣obs_init_module(obs-outputs.dll): 0.007 ms
12:18:52.948: ┃ ┣obs_init_module(obs-qsv11.dll): 6.306 ms
12:18:52.948: ┃ ┣obs_init_module(obs-text.dll): 0.132 ms
12:18:52.948: ┃ ┣obs_init_module(obs-transitions.dll): 0.005 ms
12:18:52.948: ┃ ┣obs_init_module(obs-vst.dll): 0.001 ms
12:18:52.948: ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
12:18:52.948: ┃ ┣obs_init_module(rtmp-services.dll): 0.707 ms
12:18:52.948: ┃ ┣obs_init_module(text-freetype2.dll): 0.039 ms
12:18:52.948: ┃ ┣obs_init_module(vlc-video.dll): 0.067 ms
12:18:52.948: ┃ ┣obs_init_module(win-capture.dll): 0.249 ms
12:18:52.948: ┃ ┣obs_init_module(win-decklink.dll): 2.879 ms
12:18:52.948: ┃ ┣obs_init_module(win-dshow.dll): 0.902 ms
12:18:52.948: ┃ ┣obs_init_module(win-ivcam.dll): 0.005 ms
12:18:52.948: ┃ ┣obs_init_module(win-mf.dll): 0 ms
12:18:52.948: ┃ ┣obs_init_module(win-wasapi.dll): 0.009 ms
12:18:52.948: ┃ ┗reset_win32_symbol_paths: 0.194 ms
12:18:52.948: ┣OBSBasic::ResetOutputs: 0.571 ms
12:18:52.948: ┣OBSBasic::CreateHotkeys: 0.032 ms
12:18:52.948: ┣OBSBasic::InitService: 1.243 ms
12:18:52.948: ┣OBSBasic::InitPrimitives: 0.197 ms
12:18:52.948: ┗OBSBasic::Load: 384.572 ms
12:18:52.948: obs_hotkey_thread(25 ms): min=0.003 ms, median=0.006 ms, max=9.263 ms, 99th percentile=0.301 ms, 100% below 25 ms
12:18:52.948: audio_thread(Audio): min=0 ms, median=0.029 ms, max=1.528 ms, 99th percentile=0.286 ms
12:18:52.948: obs_graphics_thread(33.3333 ms): min=0.049 ms, median=0.534 ms, max=12.463 ms, 99th percentile=3.101 ms, 100% below 33.333 ms
12:18:52.948: ┣tick_sources: min=0.001 ms, median=0.009 ms, max=5.988 ms, 99th percentile=0.106 ms
12:18:52.948: ┣output_frame: min=0.035 ms, median=0.06 ms, max=6.54 ms, 99th percentile=0.466 ms
12:18:52.948: ┃ ┗gs_context(video->graphics): min=0.035 ms, median=0.06 ms, max=6.538 ms, 99th percentile=0.463 ms
12:18:52.948: ┃ ┣render_video: min=0.011 ms, median=0.017 ms, max=1.95 ms, 99th percentile=0.141 ms
12:18:52.948: ┃ ┃ ┗render_main_texture: min=0.008 ms, median=0.012 ms, max=1.943 ms, 99th percentile=0.103 ms
12:18:52.948: ┃ ┗gs_flush: min=0.022 ms, median=0.041 ms, max=6.433 ms, 99th percentile=0.312 ms
12:18:52.949: ┗render_displays: min=0 ms, median=0.441 ms, max=12.395 ms, 99th percentile=2.532 ms
12:18:52.949: =================================================
12:18:52.949: == Profiler Time Between Calls ==================
12:18:52.949: obs_hotkey_thread(25 ms): min=24.259 ms, median=25.899 ms, max=48.175 ms, 17.1614% within ±2% of 25 ms (0.020903% lower, 82.8177% higher)
12:18:52.949: obs_graphics_thread(33.3333 ms): min=22.482 ms, median=33.333 ms, max=44.186 ms, 99.2371% within ±2% of 33.333 ms (0.381471% lower, 0.381471% higher)
12:18:52.976: Number of memory leaks: 0
PLEASE GUYS NEED HELP PLEASEEE
Hi Sir, Narcogen
Direct3D 9
I have the same problem in the game CS:GO
But there the screen stands still after 2 minutes and when I launch DotA, the process takes about 30 seconds and then the screen stands still.
