Question / Help Hey, want to start streaming and I need help setting up OBS
palshede
So about me, I play a lot of League of Legends and just got 30/30 internet at home (soon to be 50/50). With the 30/30 I thought about streaming, I have tried OBS, Xsplit and FFsplit, and every single time I streamed my games the stream lagged whenever a small fight or a big team fight started, aswell as when a game started and ended. I play with a FPS between 120-180
This picture is from the program Speccy, and it shows my computer stats.
And just a picture of my internet connection.
From these two photos I hope that someone can help me set up OBS so I'm able to stream in either 720 or 1080 without dropping insanely in FPS, so I dont get any sorts of FPS spikes, which I used to get when I first used OBS, with a FPS of ~40.
EDIT:
15:59:13: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
15:59:13: -------------------------------
15:59:13: CPU Name: AMD FX(tm)-8120 Eight-Core Processor
15:59:13: CPU Speed: 3110MHz
15:59:13: Physical Memory:  4095MB Total, 3640MB Free
15:59:13: stepping id: 2, model 1, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 4
15:59:13: monitor 1: pos={0, 0}, size={1920, 1080}
15:59:13: monitor 2: pos={-1280, 56}, size={1280, 1024}
15:59:13: Windows Version: 6.1 Build 7601 S
15:59:13: Aero is Disabled
15:59:13: OBS Modules:
15:59:13: Base Address     Module
15:59:13: 00230000         OBS.exe
15:59:13: 6CAE0000         OBSApi.dll
15:59:13: 6FF10000         DShowPlugin.dll
15:59:13: 74B30000         GraphicsCapture.dll
15:59:13: 74A30000         NoiseGate.dll
15:59:13: 749D0000         PSVPlugin.dll
15:59:13: ------------------------------------------
15:59:13: Adapter 1
15:59:13:   Video Adapter: AMD Radeon HD 6800 Series
15:59:13:   Video Adapter Dedicated Video Memory: 1062957056
15:59:13:   Video Adapter Shared System Memory: 2924705792
15:59:13: =====Stream Start: 2013-07-27, 15:59:13===============================================
15:59:13:   Multithreaded optimizations: On
15:59:13:   Base resolution: 1920x1080
15:59:13:   Output resolution: 1280x720
15:59:13: Loading up D3D10...
15:59:13: Playback device Default
15:59:13: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
15:59:13: Using auxilary audio input: Microphone (Realtek High Definition Audio)
15:59:13: Audio Encoding: AAC
15:59:13:     bitrate: 128
15:59:13: Using bitmap image
15:59:13: Using Window Capture
15:59:13: Using Monitor Capture
15:59:13: Video Encoding: x264
15:59:13:     fps: 50
15:59:13:     width: 1280, height: 720
15:59:13:     preset: veryfast
15:59:13:     CBR: no
15:59:13:     CFR: no
15:59:13:     max bitrate: 7000
15:59:13:     buffer size: 7000
15:59:13:     quality: 9
15:59:14: Total frames rendered: 55, number of frames that lagged: 4 (7.27%) (it's okay for some frames to lag)
15:59:14: =====Stream End: 2013-07-27, 15:59:14=================================================
15:59:17: =====Stream Start: 2013-07-27, 15:59:17===============================================
15:59:17:   Multithreaded optimizations: On
15:59:17:   Base resolution: 1920x1080
15:59:17:   Output resolution: 1280x720
15:59:17: ------------------------------------------
15:59:17: Loading up D3D10...
15:59:17: Playback device Default
15:59:17: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
15:59:17: Using auxilary audio input: Microphone (Realtek High Definition Audio)
15:59:17: Audio Encoding: AAC
15:59:17:     bitrate: 128
15:59:17: Using bitmap image
15:59:17: Using Window Capture
15:59:17: Using Monitor Capture
15:59:17: Video Encoding: x264
15:59:17:     fps: 50
15:59:17:     width: 1280, height: 720
15:59:17:     preset: veryfast
15:59:17:     CBR: no
15:59:17:     CFR: no
15:59:17:     max bitrate: 7000
15:59:17:     buffer size: 7000
15:59:17:     quality: 9
15:59:18: Total frames rendered: 28, number of frames that lagged: 2 (7.14%) (it's okay for some frames to lag)
15:59:18: =====Stream End: 2013-07-27, 15:59:18=================================================
15:59:18: =====Stream Start: 2013-07-27, 15:59:18===============================================
15:59:18:   Multithreaded optimizations: On
15:59:18:   Base resolution: 1920x1080
15:59:18:   Output resolution: 1280x720
15:59:18: ------------------------------------------
15:59:18: Loading up D3D10...
15:59:18: Playback device Default
15:59:18: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
15:59:18: Using auxilary audio input: Microphone (Realtek High Definition Audio)
15:59:18: Audio Encoding: AAC
15:59:18:     bitrate: 128
15:59:18: Using bitmap image
15:59:18: Using Window Capture
15:59:18: Using Monitor Capture
15:59:18: Video Encoding: x264
15:59:18:     fps: 50
15:59:18:     width: 1280, height: 720
15:59:18:     preset: veryfast
15:59:18:     CBR: no
15:59:18:     CFR: no
15:59:18:     max bitrate: 7000
15:59:18:     buffer size: 7000
15:59:18:     quality: 9
15:59:19: Total frames rendered: 9, number of frames that lagged: 2 (22.22%) (it's okay for some frames to lag)
15:59:19: =====Stream End: 2013-07-27, 15:59:19=================================================
15:59:23: =====Stream Start: 2013-07-27, 15:59:23===============================================
15:59:23:   Multithreaded optimizations: On
15:59:23:   Base resolution: 1920x1080
15:59:23:   Output resolution: 1280x720
15:59:23: ------------------------------------------
15:59:23: Loading up D3D10...
15:59:23: Playback device Default
15:59:23: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
15:59:23: Using auxilary audio input: Microphone (Realtek High Definition Audio)
15:59:23: Audio Encoding: AAC
15:59:23:     bitrate: 128
15:59:23: Using bitmap image
15:59:23: Using Window Capture
15:59:23: Using Monitor Capture
15:59:23: Video Encoding: x264
15:59:23:     fps: 50
15:59:23:     width: 1280, height: 720
15:59:23:     preset: veryfast
15:59:23:     CBR: no
15:59:23:     CFR: no
15:59:23:     max bitrate: 7000
15:59:23:     buffer size: 7000
15:59:23:     quality: 9
15:59:25: Using RTMP service: Twitch / Justin.tv
15:59:25:   Server selection: rtmp://live-fra.justin.tv/app
15:59:26: SO_SNDBUF was at 8192
15:59:26: SO_SNDBUF is now 65536
16:02:02: Using bitmap image
16:02:03: Using bitmap image
17:44:50: Total frames rendered: 269190, number of frames that lagged: 146043 (54.25%) (it's okay for some frames to lag)
17:44:50: RTMPPublisher::SocketLoop: Aborting due to bStopping
17:44:50: Number of times waited to send: 0, Waited for a total of 0 bytes
17:44:50: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
17:44:50: =====Stream End: 2013-07-27, 17:44:50=================================================
17:44:50: =====Stream Start: 2013-07-27, 17:44:50===============================================
17:44:50:   Multithreaded optimizations: On
17:44:50:   Base resolution: 1920x1080
17:44:50:   Output resolution: 1280x720
17:44:50: ------------------------------------------
17:44:50: Loading up D3D10...
17:44:50: Playback device Default
17:44:50: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
17:44:50: Using auxilary audio input: Microphone (Realtek High Definition Audio)
17:44:50: Audio Encoding: AAC
17:44:50:     bitrate: 128
17:44:51: Using bitmap image
17:44:51: Using Monitor Capture
17:44:51: ------------------------------------------
17:44:51: Video Encoding: x264
17:44:51:     fps: 30
17:44:51:     width: 1280, height: 720
17:44:51:     preset: veryfast
17:44:51:     CBR: no
17:44:51:     CFR: no
17:44:51:     max bitrate: 7000
17:44:51:     buffer size: 7000
17:44:51:     quality: 9
17:44:53: Using RTMP service: Twitch / Justin.tv
17:44:53:   Server selection: rtmp://live-fra.justin.tv/app
17:44:54: SO_SNDBUF was at 8192
17:44:54: SO_SNDBUF is now 65536
17:46:42: Total frames rendered: 3192, number of frames that lagged: 74 (2.32%) (it's okay for some frames to lag)
17:46:42: RTMPPublisher::SocketLoop: Aborting due to bStopping
17:46:42: Number of times waited to send: 0, Waited for a total of 0 bytes
17:46:42: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
17:46:42: =====Stream End: 2013-07-27, 17:46:42=================================================
17:46:42: =====Stream Start: 2013-07-27, 17:46:42===============================================
17:46:42:   Multithreaded optimizations: On
17:46:42:   Base resolution: 1920x1080
17:46:42:   Output resolution: 1280x720
17:46:42: ------------------------------------------
17:46:42: Loading up D3D10...
17:46:42: Playback device Default
17:46:42: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
17:46:42: Using auxilary audio input: Microphone (Realtek High Definition Audio)
17:46:42: Audio Encoding: AAC
17:46:42:     bitrate: 128
17:46:43: Using bitmap image
17:46:43: Using Monitor Capture
17:46:43: ------------------------------------------
17:46:43: Video Encoding: x264
17:46:43:     fps: 30
17:46:43:     width: 1280, height: 720
17:46:43:     preset: veryfast
17:46:43:     CBR: no
17:46:43:     CFR: no
17:46:43:     max bitrate: 7000
17:46:43:     buffer size: 7000
17:46:43:     quality: 9
17:46:45: Using RTMP service: Twitch / Justin.tv
17:46:45:   Server selection: rtmp://live-fra.justin.tv/app
17:46:46: SO_SNDBUF was at 8192
17:46:46: SO_SNDBUF is now 65536
17:48:11: Total frames rendered: 2592, number of frames that lagged: 134 (5.17%) (it's okay for some frames to lag)
17:48:11: RTMPPublisher::SocketLoop: Aborting due to bStopping
17:48:11: Number of times waited to send: 0, Waited for a total of 0 bytes
17:48:11: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
17:48:11: =====Stream End: 2013-07-27, 17:48:11=================================================
17:48:12: =====Stream Start: 2013-07-27, 17:48:12===============================================
17:48:12:   Multithreaded optimizations: On
17:48:12:   Base resolution: 1920x1080
17:48:12:   Output resolution: 1920x1080
17:48:12: ------------------------------------------
17:48:12: Loading up D3D10...
17:48:12: Playback device Default
17:48:12: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
17:48:12: Using auxilary audio input: Microphone (Realtek High Definition Audio)
17:48:12: Audio Encoding: AAC
17:48:12:     bitrate: 128
17:48:12: Using bitmap image
17:48:12: Using Monitor Capture
17:48:12: Video Encoding: x264
17:48:12:     fps: 30
17:48:12:     width: 1920, height: 1080
17:48:12:     preset: veryfast
17:48:12:     CBR: no
17:48:12:     CFR: no
17:48:12:     max bitrate: 7000
17:48:12:     buffer size: 7000
17:48:12:     quality: 9
17:48:14: Using RTMP service: Twitch / Justin.tv
17:48:14:   Server selection: rtmp://live-fra.justin.tv/app
17:48:16: SO_SNDBUF was at 8192
17:48:16: SO_SNDBUF is now 65536
17:49:39: Total frames rendered: 2526, number of frames that lagged: 142 (5.62%) (it's okay for some frames to lag)
17:49:39: RTMPPublisher::SocketLoop: Aborting due to bStopping
17:49:39: Number of times waited to send: 0, Waited for a total of 0 bytes
17:49:39: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
17:49:40: =====Stream End: 2013-07-27, 17:49:40=================================================
17:49:51: =====Stream Start: 2013-07-27, 17:49:51===============================================
17:49:51:   Multithreaded optimizations: On
17:49:51:   Base resolution: 1920x1080
17:49:51:   Output resolution: 1280x720
17:49:51: ------------------------------------------
17:49:51: Loading up D3D10...
17:49:51: Playback device Default
17:49:51: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
17:49:51: Using auxilary audio input: Microphone (Realtek High Definition Audio)
17:49:51: Audio Encoding: AAC
17:49:51:     bitrate: 128
17:49:51: Using bitmap image
17:49:51: Using Monitor Capture
17:49:51: Video Encoding: x264
17:49:51:     fps: 30
17:49:51:     width: 1280, height: 720
17:49:51:     preset: veryfast
17:49:51:     CBR: no
17:49:51:     CFR: no
17:49:51:     max bitrate: 7000
17:49:51:     buffer size: 7000
17:49:51:     quality: 9
17:49:53: Using RTMP service: Twitch / Justin.tv
17:49:53:   Server selection: rtmp://live-fra.justin.tv/app
17:49:55: SO_SNDBUF was at 8192
17:49:55: SO_SNDBUF is now 65536
17:51:59: Total frames rendered: 3633, number of frames that lagged: 90 (2.48%) (it's okay for some frames to lag)
17:51:59: RTMPPublisher::SocketLoop: Aborting due to bStopping
17:51:59: Number of times waited to send: 0, Waited for a total of 0 bytes
17:51:59: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
17:51:59: =====Stream End: 2013-07-27, 17:51:59=================================================
17:54:29: Using fixed low latency mode, factor 20
17:54:29: =====Stream Start: 2013-07-27, 17:54:29===============================================
17:54:29:   Multithreaded optimizations: On
17:54:29:   Base resolution: 1920x1080
17:54:29:   Output resolution: 1920x1080
17:54:29: ------------------------------------------
17:54:29: Loading up D3D10...
17:54:29: Playback device Default
17:54:29: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
17:54:29: Using auxilary audio input: Microphone (Realtek High Definition Audio)
17:54:29: Audio Encoding: AAC
17:54:29:     bitrate: 128
17:54:29: Using bitmap image
17:54:29: Using Monitor Capture
17:54:29: Video Encoding: x264
17:54:29:     fps: 30
17:54:29:     width: 1920, height: 1080
17:54:29:     preset: veryfast
17:54:29:     CBR: no
17:54:29:     CFR: no
17:54:29:     max bitrate: 8500
17:54:29:     buffer size: 8500
17:54:29:     quality: 9
17:54:31: Using RTMP service: Twitch / Justin.tv
17:54:31:   Server selection: rtmp://live-fra.justin.tv/app
17:54:32: SO_SNDBUF was at 8192
17:54:32: SO_SNDBUF is now 65536
17:58:21: Total frames rendered: 6626, number of frames that lagged: 449 (6.78%) (it's okay for some frames to lag)
17:58:21: RTMPPublisher::SocketLoop: Aborting due to loop exit
17:58:21: Number of times waited to send: 0, Waited for a total of 0 bytes
17:58:21: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
17:58:22: =====Stream End: 2013-07-27, 17:58:22=================================================
18:09:39: Using fixed low latency mode, factor 20
18:09:39: =====Stream Start: 2013-07-27, 18:09:39===============================================
18:09:39:   Multithreaded optimizations: On
18:09:39:   Base resolution: 1920x1080
18:09:39:   Output resolution: 1280x720
18:09:39: ------------------------------------------
18:09:39: Loading up D3D10...
18:09:39: Playback device Default
18:09:39: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
18:09:39: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:09:39: Audio Encoding: AAC
18:09:39:     bitrate: 256
18:09:39: Using bitmap image
18:09:39: Using Monitor Capture
18:09:39: Video Encoding: x264
18:09:39:     fps: 60
18:09:39:     width: 1280, height: 720
18:09:39:     preset: veryfast
18:09:39:     CBR: yes
18:09:39:     CFR: no
18:09:39:     max bitrate: 4000
18:09:41: Using RTMP service: Twitch / Justin.tv
18:09:41:   Server selection: rtmp://live-fra.justin.tv/app
18:09:42: SO_SNDBUF was at 8192
18:09:42: SO_SNDBUF is now 65536
18:11:04: x264: VBV parameters cannot be changed when NAL HRD is in use
18:11:09: Total frames rendered: 4121, number of frames that lagged: 3181 (77.19%) (it's okay for some frames to lag)
18:11:10: RTMPPublisher::SocketLoop: Aborting due to loop exit
18:11:10: Number of times waited to send: 0, Waited for a total of 0 bytes
18:11:10: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:11:10: =====Stream End: 2013-07-27, 18:11:10=================================================
18:11:21: Using fixed low latency mode, factor 20
18:11:21: =====Stream Start: 2013-07-27, 18:11:21===============================================
18:11:21:   Multithreaded optimizations: On
18:11:21:   Base resolution: 1920x1080
18:11:21:   Output resolution: 1280x720
18:11:21: ------------------------------------------
18:11:21: Loading up D3D10...
18:11:21: Playback device Default
18:11:21: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
18:11:21: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:11:21: Audio Encoding: AAC
18:11:21:     bitrate: 256
18:11:21: Using bitmap image
18:11:21: Using Monitor Capture
18:11:21: Video Encoding: x264
18:11:21:     fps: 60
18:11:21:     width: 1280, height: 720
18:11:21:     preset: veryfast
18:11:21:     CBR: yes
18:11:21:     CFR: no
18:11:21:     max bitrate: 7000
18:11:23: Using RTMP service: Twitch / Justin.tv
18:11:23:   Server selection: rtmp://live-fra.justin.tv/app
18:11:25: SO_SNDBUF was at 8192
18:11:25: SO_SNDBUF is now 65536
18:12:30: Total frames rendered: 3130, number of frames that lagged: 2918 (93.23%) (it's okay for some frames to lag)
18:12:30: RTMPPublisher::SocketLoop: Aborting due to loop exit
18:12:30: Number of times waited to send: 0, Waited for a total of 0 bytes
18:12:30: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:12:30: =====Stream End: 2013-07-27, 18:12:30=================================================
18:12:45: Using fixed low latency mode, factor 20
18:12:45: =====Stream Start: 2013-07-27, 18:12:45===============================================
18:12:45:   Multithreaded optimizations: On
18:12:45:   Base resolution: 1920x1080
18:12:45:   Output resolution: 1280x720
18:12:45: ------------------------------------------
18:12:45: Loading up D3D10...
18:12:45: Playback device Default
18:12:45: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
18:12:45: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:12:45: Audio Encoding: AAC
18:12:45:     bitrate: 256
18:12:45: Using bitmap image
18:12:45: Using Monitor Capture
18:12:45: Video Encoding: x264
18:12:45:     fps: 60
18:12:45:     width: 1280, height: 720
18:12:45:     preset: veryfast
18:12:45:     CBR: no
18:12:45:     CFR: no
18:12:45:     max bitrate: 7000
18:12:45:     buffer size: 7000
18:12:45:     quality: 9
18:12:46: Using RTMP service: Twitch / Justin.tv
18:12:46:   Server selection: rtmp://live-fra.justin.tv/app
18:12:48: Total frames rendered: 150, number of frames that lagged: 23 (15.33%) (it's okay for some frames to lag)
18:12:48: SO_SNDBUF was at 8192
18:12:48: SO_SNDBUF is now 65536
18:12:48: RTMPPublisher::SocketLoop: Aborting due to loop exit
18:12:48: Number of times waited to send: 0, Waited for a total of 0 bytes
18:12:48: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
18:12:48: =====Stream End: 2013-07-27, 18:12:48=================================================
18:26:40: Using fixed low latency mode, factor 20
18:26:40: =====Stream Start: 2013-07-27, 18:26:40===============================================
18:26:40:   Multithreaded optimizations: On
18:26:40:   Base resolution: 1920x1080
18:26:40:   Output resolution: 1280x720
18:26:40: ------------------------------------------
18:26:40: Loading up D3D10...
18:26:40: Playback device {0.0.0.00000000}.{fed96aa6-4bc2-4667-865d-b773140ea098}
18:26:40: Using desktop audio input: Steelseries headset (Realtek High Definition Audio)
18:26:40: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:26:41: ------------------------------------------
18:26:41: Audio Encoding: AAC
18:26:41:     bitrate: 128
18:26:41: Using bitmap image
18:26:41: Using Monitor Capture
18:26:41: Video Encoding: x264
18:26:41:     fps: 29
18:26:41:     width: 1280, height: 720
18:26:41:     preset: veryfast
18:26:41:     CBR: no
18:26:41:     CFR: no
18:26:41:     max bitrate: 5500
18:26:41:     buffer size: 5500
18:26:41:     quality: 10
18:26:43: Using RTMP service: Twitch / Justin.tv
18:26:43:   Server selection: rtmp://live-fra.justin.tv/app
18:26:44: SO_SNDBUF was at 8192
18:26:44: SO_SNDBUF is now 65536
18:28:42: Using Monitor Capture
18:31:31: Using Monitor Capture
18:32:17: Total frames rendered: 9283, number of frames that lagged: 689 (7.42%) (it's okay for some frames to lag)
18:32:17: RTMPPublisher::SocketLoop: Aborting due to loop exit
18:32:17: Number of times waited to send: 0, Waited for a total of 0 bytes
18:32:17: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:32:17: =====Stream End: 2013-07-27, 18:32:17=================================================
20:47:57:
20:47:57: Profiler results:
20:47:57:
20:47:57: ==============================================================
20:47:57: frame - [100%] [avg time: 20.717 ms (cpu time: avg 11.569 ms, total 3.52317e+006 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0338%]
20:47:57: | frame preprocessing and rendering - [79.7%] [avg time: 16.519 ms (cpu time: avg 9.292 ms, total 2.82992e+006 ms)] [avg calls per frame: 1] [children: 78%] [unaccounted: 1.77%]
20:47:57: | | scene->Preprocess - [78%] [avg time: 16.153 ms (cpu time: avg 9.012 ms, total 2.74456e+006 ms)] [avg calls per frame: 1]
20:47:57: | video encoding and uploading - [20.2%] [avg time: 4.191 ms (cpu time: avg 2.272 ms, total 692021 ms)] [avg calls per frame: 1] [children: 20%] [unaccounted: 0.183%]
20:47:57: | | flush - [9.48%] [avg time: 1.964 ms (cpu time: avg 0.126 ms, total 38423 ms)] [avg calls per frame: 1]
20:47:57: | | CopyResource - [0.0579%] [avg time: 0.012 ms (cpu time: avg 0.011 ms, total 3588.02 ms)] [avg calls per frame: 0]
20:47:57: | | conversion to 4:2:0 - [0.0772%] [avg time: 0.016 ms (cpu time: avg 0.012 ms, total 3915.63 ms)] [avg calls per frame: 0]
20:47:57: | | call to encoder - [10.3%] [avg time: 2.128 ms (cpu time: avg 2.068 ms, total 630073 ms)] [avg calls per frame: 0]
20:47:57: | | sending stuff out - [0.159%] [avg time: 0.033 ms (cpu time: avg 0.027 ms, total 8252.46 ms)] [avg calls per frame: 0]
20:47:57: | Convert444Threads - [237%] [avg time: 49.037 ms (cpu time: avg 2.457 ms, total 748430 ms)] [avg calls per frame: 1]
20:47:57:
