Question / Help Help with system/obs settings
JJohnRJ
Hello, everyone.
Im looking for help with system / obs settings. I basically want to stream minecraft. However when I try to stream / record / preview stream, the game 'minecraft' drops from 400fps to 120fps with constant lag spikes.
I've browsed the forum for similar situations and solutions, and made adjustments.
- Changed settings to preformance on nvidia control panel
- Adjusted in game settings
- adjusted obs settings according to the estimator
To be honest I think it could be that my pc (which was prebuilt) is ''outdated''.
Got any suggestions?
All the help is highly appreciated! thank you.
15:18:59: Open Broadcaster Software v0.613b - 64bit ( ^ω^)
15:18:59: -------------------------------
15:18:59: CPU Name: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
15:18:59: CPU Speed: 3400MHz
15:18:59: Physical Memory:  16334MB Total, 10394MB Free
15:18:59: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
15:18:59: monitor 1: pos={0, 0}, size={1366, 768}
15:18:59: monitor 2: pos={1366, -195}, size={1920, 1080}
15:18:59: Windows Version: 6.2 Build 9200
15:18:59: Aero is Enabled
15:18:59: OBS Modules:
15:18:59: Base Address     Module
15:18:59: 0000000007430000 OBS.exe
15:18:59: 00000000BDEC0000 OBSApi.dll
15:18:59: 00000000C2290000 DShowPlugin.dll
15:18:59: 00000000BF690000 GraphicsCapture.dll
15:18:59: 00000000C2270000 NoiseGate.dll
15:18:59: 00000000BF3B0000 PSVPlugin.dll
15:18:59: ------------------------------------------
15:18:59: Adapter 1
15:18:59:   Video Adapter: NVIDIA GeForce GT 640
15:18:59:   Video Adapter Dedicated Video Memory: 1012592640
15:18:59:   Video Adapter Shared System Memory: 3221549056
15:18:59:   Video Adapter Output 1: pos={0, 0}, size={1366, 768}, attached=true
15:18:59:   Video Adapter Output 2: pos={1366, -195}, size={1920, 1080}, attached=true
15:18:59: =====Stream Start: 2014-04-09, 15:18:59===============================================
15:18:59:   Multithreaded optimizations: On
15:18:59:   Base resolution: 1280x720
15:18:59:   Output resolution: 1280x720
15:18:59: Loading up D3D10 on NVIDIA GeForce GT 640 (Adapter 1)...
15:18:59: Audio Format: 48000 Hz
15:18:59: Audio Channels: 2 Ch
15:18:59: Playback device {0.0.0.00000000}.{9089a4c9-d727-4428-992d-df5c62737a7f}
15:18:59: Using desktop audio input: Headset Earphone (4- ASTRO MixAmp Pro           )
15:18:59: Using auxilary audio input: Headset Microphone (4- ASTRO MixAmp Pro           )
15:18:59: Audio Encoding: AAC
15:18:59:     bitrate: 128
15:18:59: Using bitmap image
15:18:59: Scene buffering time set to 700
15:18:59: Video Encoding: x264
15:18:59:     fps: 60
15:18:59:     width: 1280, height: 720
15:18:59:     preset: veryfast
15:18:59:     profile: high
15:18:59:     keyint: 250
15:18:59:     CBR: yes
15:18:59:     CFR: yes
15:18:59:     max bitrate: 3000
15:18:59:     buffer size: 3000
15:19:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:19:01:   New Scene
15:19:01: Using bitmap image
15:19:01:   New Scene
15:19:01: Using graphics capture
15:19:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:19:02:   New Scene
15:19:02: Using bitmap image
15:19:05: Total frames encoded: 269, total frames duplicated: 0 (0.00%)
15:19:05: Total frames rendered: 276, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
15:19:05:
15:19:05: Profiler time results:
15:19:05:
15:19:05: ==============================================================
15:19:05: video thread frame - [100%] [avg time: 0.666 ms] [children: 16.4%] [unaccounted: 83.6%]
15:19:05: | scene->Preprocess - [0.15%] [avg time: 0.001 ms]
15:19:05: | GPU download and conversion - [16.2%] [avg time: 0.108 ms] [children: 13.2%] [unaccounted: 3%]
15:19:05: | | flush - [10.5%] [avg time: 0.07 ms]
15:19:05: | | CopyResource - [2.4%] [avg time: 0.016 ms]
15:19:05: | | conversion to 4:2:0 - [0.3%] [avg time: 0.002 ms]
15:19:05: Convert444Threads - [100%] [avg time: 0.442 ms] [children: 99.3%] [unaccounted: 0.679%]
15:19:05: | Convert444toNV12 - [99.3%] [avg time: 0.439 ms]
15:19:05: encoder thread frame - [100%] [avg time: 0.894 ms] [children: 0.112%] [unaccounted: 99.9%]
15:19:05: | sending stuff out - [0.112%] [avg time: 0.001 ms]
15:19:05:
15:19:05:
15:19:05: Profiler CPU results:
15:19:05:
15:19:05: video thread frame - [cpu time: avg 0.056 ms, total 15.625 ms] [avg calls per frame: 1]
15:19:05: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:19:05: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:19:05: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:19:05: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:19:05: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:19:05: Convert444Threads - [cpu time: avg 0.411 ms, total 187.5 ms] [avg calls per frame: 2]
15:19:05: | Convert444toNV12 - [cpu time: avg 0.411 ms, total 187.5 ms] [avg calls per frame: 2]
15:19:05: encoder thread frame - [cpu time: avg 0.344 ms, total 78.125 ms] [avg calls per frame: 1]
15:19:05: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:19:05:
15:19:05: =====Stream End: 2014-04-09, 15:19:05=================================================
Last game capture log:
2014-04-09, 14:33:52: we're booting up:
14:33:52: CaptureThread: attached to process javaw.exe
14:33:52: NV Capture available
14:33:52: FBO available
14:33:52: GL Present
14:33:52: (half life scientist) everything..  seems to be in order
14:33:52: SwapBuffers(2852197914) Called
14:33:52: setting up gl data
14:33:52: share device: 610701280
14:33:52: share texture: 608614384
14:33:52: share device handle: 3886560302
14:33:52: share texture handle: 4152390978
14:33:52: DoGLGPUHook: success
14:33:52: wglSwapBuffers(2852197914) Called
14:36:11: stop requested, terminating gl capture
14:36:11: ---------------------- Cleared OpenGL Capture ----------------------
14:36:11: wglSwapBuffers(2852197914) Called
14:36:11: setting up gl data
14:36:11: SwapBuffers(2852197914) Called
14:36:32: share device: 877363488
14:36:32: share texture: 608611632
14:36:32: share device handle: 3782748606
14:36:32: share texture handle: 4152395170
14:36:32: DoGLGPUHook: success
14:36:39: stop requested, terminating gl capture
14:36:39: ---------------------- Cleared OpenGL Capture ----------------------
14:36:39: wglSwapBuffers(2852197914) Called
14:36:39: setting up gl data
14:36:39: SwapBuffers(2852197914) Called
14:37:24: share device: 737285408
14:37:24: share texture: 608613872
14:37:24: share device handle: 3782748190
14:37:24: share texture handle: 4152399362
14:37:24: DoGLGPUHook: success
14:38:27: stop requested, terminating gl capture
14:38:27: ---------------------- Cleared OpenGL Capture ----------------------
14:38:27: wglSwapBuffers(2852197914) Called
14:38:27: setting up gl data
14:38:27: SwapBuffers(2852197914) Called
14:38:28: share device: 737281296
14:38:28: share texture: 608612144
14:38:28: share device handle: 4166152590
14:38:28: share texture handle: 4152403554
14:38:28: DoGLGPUHook: success
14:38:57: stop requested, terminating gl capture
14:38:57: ---------------------- Cleared OpenGL Capture ----------------------
14:38:57: wglSwapBuffers(2852197914) Called
14:38:57: setting up gl data
14:38:57: SwapBuffers(2852197914) Called
14:39:01: share device: 737281296
14:39:01: share texture: 608612720
14:39:01: share device handle: 3782747870
14:39:01: share texture handle: 4152403554
14:39:01: DoGLGPUHook: success
14:39:05: stop requested, terminating gl capture
14:39:05: ---------------------- Cleared OpenGL Capture ----------------------
14:39:05: wglSwapBuffers(2852197914) Called
14:39:05: setting up gl data
14:39:05: SwapBuffers(2852197914) Called
14:44:01: share device: 737281296
14:44:01: share texture: 608616624
14:44:01: share device handle: 3782748190
14:44:01: share texture handle: 4152403554
14:44:01: DoGLGPUHook: success
14:47:31: stop requested, terminating gl capture
14:47:31: ---------------------- Cleared OpenGL Capture ----------------------
14:47:31: wglSwapBuffers(2852197914) Called
14:47:31: setting up gl data
14:47:31: SwapBuffers(2852197914) Called
I don't particularly see anything wrong with the log file. Looks great on OBS' end in fact. Do you happen to have a video of this issue?
